Trouble starting...then something unexpected...
Old Aug 21, 2005 | 04:54 PM
mykg4orce's Avatar
Default Trouble starting...then something unexpected...
Ok I tried starting up the car....well it wouldnt. Then tried again and held the key down untill it finall started. But the wierd thing was that when I put the car into drive. On the display the red outline on 'P' was still lit and the green outline around 'D' was flashing. Also the car required a lot more gas to get it to move a little. Turned the car off, then on again....everything now back to normal. ??????
92 accord, 4door LX. No aftermarket mods. Stock.
Old Aug 23, 2005 | 10:28 AM
mykg4orce's Avatar
Default Re: Trouble starting...then something unexpected... (mykg4orce)
no help??? no thoughts....ok thanks anyways.
Old Aug 24, 2005 | 04:30 AM
JimBlake's Avatar
Flashing 'D' lamp is what the tranny controller uses for a warning light, just like the engine controller uses the 'check engine' light.
Search around for a procedure for your year to read ECU error codes. You either pull back the carpet & watch a blinking red light, or you find a plug & jumper it with a paperclip. The tranny controller has it's own set of codes just like the engine controller.
EKcivicEK
Jul 17, 2010 09:45 PM
jamzm101
Apr 2, 2007 12:00 PM
jrbling
Sep 8, 2004 09:15 PM
jason_alt
Mar 3, 2004 07:08 PM
