VTEC NOT ENGAGING
Old Aug 21, 2005 | 04:11 PM
da9driver's Avatar
Default VTEC NOT ENGAGING
LS VTEC w/chipped P28....what are the possible factors of VTEC not engaging?
Old Aug 21, 2005 | 04:15 PM
Stoich EG2's Avatar
Default Re: VTEC NOT ENGAGING (da9driver)
this is where the search is MOST useful... too bad it's DOWN!
There could be many possibilities as to why VTEC is not engaging. i'll list some:
-dented oil pan (oil pickup)
-go at least 25mph (?)
-be at operating temp
-disconnected wires/plugs
-grounds
-not enough oil
the list can go on and on. try pulling any CEL codes
Old Aug 21, 2005 | 04:17 PM
da9driver's Avatar
Default Re: VTEC NOT ENGAGING (ADVAN EG2)
could an oil leak from the oil pan prevent from having enough oil pressure? PSI is supposed to be at 60 when VTEC engages right?
Old Aug 21, 2005 | 04:19 PM
SlowD16Civic's Avatar
check your oil.....i know mine leaks a little and when it gets low it kinda gives u a misisng feeling when it hits v-tec and if u dont put any in it, then it wont even kick in.....and also they are temperature actuated.......so it wont kick in if it is cold....prolly already knew all this but just thought i would tell ya-
Old Aug 21, 2005 | 04:20 PM
robbie_R(eg6)'s Avatar
oil viscosity could be too thick also, gotta be atlease 5 w 30
Stoich EG2's Avatar
MINOR oil leaks shouldn't be a problem but if it's dripping... that could be a problem
Old Aug 21, 2005 | 04:30 PM
IlIkEg's's Avatar
Yeah...mine's drippin' but i just picked up a oil pan gasket just to be sure. VTEC does not engage at all. I haven't had a chance to do an oil change since i bought the car, but did need to add some(used Quaker Fully Synthetic 5w30). Oil Pressure PSI? Oh yeah....changed my username.
Old Aug 21, 2005 | 04:33 PM
sounds good next time u do a full oil change make sure to use 5w
Old Aug 21, 2005 | 04:40 PM
IlIkEg's's Avatar
Default Re: (robbie_R(eg6))
Can a mod please promote me from trial user? Formerly da9driver
Old Aug 21, 2005 | 07:04 PM
IlIkEg's's Avatar
Default Re: (IlIkEg's)
Tried my friends chipped P28 at 5000 and still no VTEC poppin'. Man this is annoying the hell outta me. All i can think of now is the oil pressure or the solenoid.?
Old Aug 21, 2005 | 07:43 PM
IlIkEg's's Avatar
Anybody??? Any suggestions of what to check first?
Old Aug 24, 2005 | 08:34 PM
IlIkEg's's Avatar
Solenoid works, did oil change. Still no VTEC!!! Threw code 22, which is the VTEC pressure valve. I do have the green plug, could this mean that the plug is simply no good?
Old Aug 24, 2005 | 08:36 PM
IlIkEg's's Avatar
Also...I threw code 1, o2 Sensor. I was wondering if having a bad sensor like that could VTEC into limp mode?
Old Aug 24, 2005 | 08:37 PM
IlIkEg's's Avatar
Going to work Bump
Old Aug 24, 2005 | 09:48 PM
SiR:Mallard's Avatar
I'm pretty sure any emissions related cel codes automatically put the ecu in full limp mode. You need to tackle those cels because they are probably the root of your problem.
Old Aug 24, 2005 | 10:05 PM
SirRevvs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robbie_R(eg6) &raquo;</TD></TR><TR><TD CLASS="quote">oil viscosity could be too thick also, gotta be atlease 5 w 30</TD></TR></TABLE>
I hope your not serious. You just made this guy change his oil for no reason. Although oil changes never hurt. If your throwing a CEL, the ECU could be running limp. Check your oil level, continuity between ECU and VTEC selenoid, and your wiring. Did this just start or has it never worked?
Old Aug 24, 2005 | 10:07 PM
SirRevvs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IlIkEg’s &raquo;</TD></TR><TR><TD CLASS="quote">Solenoid works, did oil change. Still no VTEC!!! Threw code 22, which is the VTEC pressure valve. I do have the green plug, could this mean that the plug is simply no good?</TD></TR></TABLE>
There's your problem check it out and go from there
Old Aug 24, 2005 | 10:17 PM
delsolgirl's Avatar
I'm have a similar problem. Checked the ecu, switched it; the solenoid, spool valve and oil pressure switch, switched them, still did not work. Checked the oil pressure, still does not work; changed the oil, still does not engage the vtec, the oil pan is ok, no dripping oil; rewired the solenoid to the ecu, still does not work. Still gives a code 22. Bought a new oil pressure switch. Still no go. Can't figure it out. Maybe the oil pump? I give up. I am taking it to Honda.
Old Aug 24, 2005 | 10:20 PM
SirRevvs's Avatar
Default Re: VTEC NOT ENGAGING (delsolgirl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsolgirl &raquo;</TD></TR><TR><TD CLASS="quote"> I am taking it to Honda.</TD></TR></TABLE>
Will Honda work on a LS/VTEC?
Old Aug 24, 2005 | 10:22 PM
delsolgirl's Avatar
What is a green plug?
Old Aug 24, 2005 | 10:25 PM
delsolgirl's Avatar
Default Re: VTEC NOT ENGAGING (SirRevvs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs &raquo;</TD></TR><TR><TD CLASS="quote">
Will Honda work on a LS/VTEC?</TD></TR></TABLE>
You have a non vtec block?
Old Aug 24, 2005 | 10:30 PM
SirRevvs's Avatar
You have a non vtec block?</TD></TR></TABLE>
No I thought since this thread was stated by a guy with LS/VTEC, and you replied with the same problem, that you also had a LS/VTEC. Sorry for the assumtion but no I have a C1 in a 94 coupe. Which I also think Honda would not work on.
Old Aug 24, 2005 | 10:35 PM
delsolgirl's Avatar
No I thought since this thread was stated by a guy with LS/VTEC, and you replied with the same problem, that you also had a LS/VTEC. Sorry for the assumtion but no I have a C1 in a 94 coupe. Which I also think Honda would not work on.</TD></TR></TABLE>
My car was stolen and screwed around with really bad and it is still all screwed up.
Old Aug 24, 2005 | 11:09 PM
JDMbiAtcH's Avatar
computer,oil line clogged,vtec wiring,low on oil,bad solenoid.
Old Aug 25, 2005 | 01:00 PM
IlIkEg's's Avatar
Default Re: VTEC NOT ENGAGING (JDMbiAtcH)
Can a moderator please promote me from a trial user....thanx!
jordan_rael_420
Sep 17, 2008 04:07 PM
h22ek9forme
10
Nov 6, 2007 11:26 PM
Dr Wylee
Apr 19, 2007 02:23 PM
digitalh3lix
Nov 21, 2004 11:01 AM
thehondaguru
Dec 31, 2002 03:23 AM
