Carb cleaner. Bad for paint?
Old Aug 21, 2005 | 04:03 PM
SlobberGoat's Avatar
Default Carb cleaner. Bad for paint?
I did a search and came up with nada.
I'm removing the sound-deadner from on of my CRXs (the slow way), and some1 suggested I use a can of carb-cleaner (spray can) to remove the gooey residue.
I just wanted to know whether it would damage the paint?
Old Aug 21, 2005 | 05:59 PM
8Si8's Avatar
Default Re: Carb cleaner. Bad for paint? (SlobberGoat)
it can ruin the paint just don't let it sit there on the paint for too long and it will be fine do a lot of wiping with a clean cloth
Old Aug 21, 2005 | 07:49 PM
Crx Jimmy's Avatar
dont get it on exterior paint it will leave spots, but inside its ok just wipe it off i used it to get all the gunk out of the engine bay when my motor was removed, if it sits too long the paint wipes off with the gunk
Old Aug 21, 2005 | 08:46 PM
Tyson's Avatar
carb cleaner is a heavy solvent. it will dissolve your paint. not instantaneously, but if you start rubbing excessively with carb cleaner, you will find your rag becoming the same color as your paint...
new_ek_owner23
Paint and Body
12
Jan 23, 2015 09:23 PM
jaydem7
Paint and Body
Sep 11, 2007 10:52 AM
peiku
Jul 25, 2005 10:49 PM
deeweezy
Aug 17, 2003 07:19 AM
VTECTIME
Sep 7, 2002 06:50 PM
