Crower Cams
Old Aug 21, 2005 | 11:29 AM
bcborn's Avatar
Default Crower Cams
Anyone with hands on comments on the new Crower D16Z6 turbo cam.
P/N 63441ZT
Old Aug 21, 2005 | 08:22 PM
bcborn's Avatar
Default Re: Crower Cams (Mysterious Bob)
anyone
Old Aug 22, 2005 | 05:36 AM
civicross's Avatar
What would you like to know?
Old Aug 22, 2005 | 08:02 AM
bcborn's Avatar
Default Re: Crower Cams (civicross)
Ony concerns regarding idle, emmissions testing, how does it perform, how does it compare to Comp/Zex, etc...
Old Aug 22, 2005 | 10:38 AM
civicross's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mysterious Bob &raquo;</TD></TR><TR><TD CLASS="quote">Ony concerns regarding idle, emmissions testing, how does it perform, how does it compare to Comp/Zex, etc...</TD></TR></TABLE>
The idle isn't as easy as stock, it does lope a bit, but it isn't a huge lope. It isn't designed as an emissions legal cam so I can't answer that question, and it performs very well, as long as you have similar mods to compliment the cam.
Old Aug 22, 2005 | 10:53 AM
bcborn's Avatar
The head is port and polished, .5mm oversize valves. The block is .020 over with ENDYN Turbo Rollerwaves (~ 9.5:1), Eagle Rods, Balanced, aluminium flywheel, RC 270 CC Injectors, 3" cold air intake, MSD Ignition, Hondata S100 with boost option.
This is the combination while we break in the new motor. Once broken in we will change injectors, TB and install the GT28RS (Disco Potato).
Hoping running this cam N/A initially is ok.
Old Aug 22, 2005 | 11:40 AM
civicross's Avatar
It is a conservative cam so NA use would be fine.
Old Aug 22, 2005 | 11:48 AM
bcborn's Avatar
Any comments regarding comparison to Zex/Comp 100 and 300 cams
psegs80
Nov 25, 2005 08:36 PM
HondaTeg95
Aug 26, 2005 07:10 PM
.dave
Aug 19, 2005 10:20 AM
tpb18b1
Apr 10, 2005 04:30 PM
Mr.DC2TurBo
Sep 5, 2004 06:42 PM
