Performance radiator?
Go with the Fludine, you can use the flyudine rad from the 92-95 civics in your CRX, it's smaller and works the same as the CRX one, thus allowing lot's of room a turbo...
And you'll PAY for the fluidyne too... $300or more vs $125. Your choice.
Ignore the clearance between the header and the radiator because this is not a a normal size header. But this will give you a idea of clearance with Hasport mounts(non billet) and a bseries motor.
