Compressing rear calipers?
you gotta turn them back. either use a disk brake tool that you can rent from Autozone or Pep Boys, or you can try to use a pair of vice grips. Open them up so they fit into each side of the grooves(+ on the piston and turn them counter clockwise til they are flush
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_91si »</TD></TR><TR><TD CLASS="quote">you gotta turn them back. either use a disk brake tool that you can rent from Autozone or Pep Boys, or you can try to use a pair of vice grips. Open them up so they fit into each side of the grooves(+ on the piston and turn them counter clockwise til they are flush
good luck</TD></TR></TABLE>
It was clockwise, but thank you very much
