First time at the drag strip with the R...
Well i decied to take the R to the track last night to see what she'll do... it was a very hot and humid night so everyone was runing alittle bit slower than normal...
first here are my mods,
Act Clutch
Act flywheel (8lbs)
Invidia test pipe
Kenji chipped Ecu ( 9200rpms)
Apexi V-AFC
ATS final drive ( 4.9 FD)
Mugen exhaust
Skunk 2 cam gears
TODA valve springs
Mugen head gasket (11.1 comp )
Injen cold air intake
Strup JDM 4-1 header
the car dynoed 192whp on a dyno jet... (tuned by jack@p1)
my first run,
R/T..... .578
60....... 2.632 (
330..... 6.517
1/8...... 9.658
MPH..... 77.84
1000.... 12.430
1/4...... 14.830
MPH..... 97.67
second run (last run of the night)
R/T..... .563
60....... 2.477 (
330..... 6.235
1/8...... 9.442
MPH..... 79.69
1000.... 11.954
1/4...... 14.5
MPH..... 100.72
not bad for my first time out. She has 13's in her, i just need more seat time
Act Clutch
Act flywheel (8lbs)
Invidia test pipe
Apexi V-AFC
Mugen exhaust
Skunk 2 cam gears
TODA valve springs
my first run,
R/T..... .578
60....... 2.632 (
)330..... 6.517
1/8...... 9.658
MPH..... 77.84
1000.... 12.430
1/4...... 14.830
MPH..... 97.67
R/T..... .563
60....... 2.477 (
)330..... 6.235
1/8...... 9.442
MPH..... 79.69
1000.... 11.954
1/4...... 14.5
MPH..... 100.72
most definitely at 13 car.....
nail down the launch to a 2.2xx and you're there...
try deflating your front tires for some better grip.... I used to run 17-20psi on the stock RE010s for my particular dragstrip.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekay_jeremy »</TD></TR><TR><TD CLASS="quote">easy 13 sec car</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastvtecCL »</TD></TR><TR><TD CLASS="quote">
Did just the head gasket raise your compression .5?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nholmes »</TD></TR><TR><TD CLASS="quote">
yes it did
</TD></TR></TABLE>yes it did
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowyellow »</TD></TR><TR><TD CLASS="quote">hmmm only 14s? i was expecting mid 13s or so.</TD></TR></TABLE>
thats what i'm hoping for, but remember this was my first time to the track with this car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cryptikman »</TD></TR><TR><TD CLASS="quote">Those are decent times, just work on your launches. Good luck and hopefully soon you will be in the 13's.</TD></TR></TABLE>
From: Somewhere in a DC2.... Supporting the ITR Militia, USA
As stated above DO try slipping the clutch at launch and drop your tire pressure..... VERY EASY 13's caR..... What RPM are you launching at? I got my best times STOCK .... 14.7@102 .... by going with a VTEC engagement point launch... (around 5600) Slipping the clutch..... But now "mildly modded" I get down low and roll out on the clutch.... But remember, YOUR FIRST TIME...... You'll get learn it in no time flat...... NOW GO PRACTICE IN A PARKING LOT !!!!!!!
Definately have to spin the tires a bit off the launch because you need to be above 5800 when you get 100% traction and go WOT.
..and 14.7 @ 101 stock? WTF? Freak pass with a 2.7 60 perhaps?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 »</TD></TR><TR><TD CLASS="quote">192 whp on stock cams? how much more power did the vafc make? meaning did it help at all?</TD></TR></TABLE>
yes the 192whp is on stock cams... the v-afc helped out alot, but it was jack@P1 that tuned the car for me and was able to get alot more power out of the v-afc for me...
