need a good piston & rod combo on stock sleevs B16A2 for 20PSI
Old Aug 21, 2005 | 01:15 AM
RACEPAK's Avatar
Default need a good piston & rod combo on stock sleevs B16A2 for 20PSI
hello everybody.
got a b16a2 that's waiting for a rebuild for boost.
i need you guys to recommend me a good piston & rod setup for reliable power.
i was thinking about tuner toys rods and wisco or je pistons and arp studs ?!?
what about head gasket should i go oem or other brand?
also which piston rings do you guys recommend?
best regards moshik galimidi
Old Aug 21, 2005 | 01:21 AM
T4eg's Avatar
Default Re: need a good piston & rod combo on stock sleevs B16A2 for 20PSI (RACEPAK)
eagle rods CP pistons
Old Aug 21, 2005 | 06:53 AM
Makdaddynuge's Avatar
Default Re: need a good piston & rod combo on stock sleevs B16A2 for 20PSI (T4eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T4eg &raquo;</TD></TR><TR><TD CLASS="quote">eagle rods CP pistons </TD></TR></TABLE>
Old Aug 21, 2005 | 06:54 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: need a good piston & rod combo on stock sleevs B16A2 for 20PSI (Makdaddynuge)
manley rods, cp pistons, oem headgasket, darton mid or golden eagle hd sleeves, arp or goldeneagle head studs
Old Aug 21, 2005 | 07:28 AM
BlueShadow's Avatar
Default Re: need a good piston & rod combo on stock sleevs B16A2 for 20PSI (wantboost)
-Pauter or Manley rods
-CP pistons
-Cometic MLS HG or OEM if you stick with stock bore size
-ARP head studs
-ARP rod and main bolts
Old Aug 21, 2005 | 07:47 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: need a good piston & rod combo on stock sleevs B16A2 for 20PSI (BlueShadow)
manley and pauter rods come with arp2000 rod bolts. and the stock mani blts are more than enough. all the mani studs do is cause you to have to linebore your block which is about 220 bucks
Old Aug 21, 2005 | 08:56 AM
mrbsponge's Avatar
i am using JE pistons and a set of crower rods, have gone over 20 daily and havent had a problem in 2 years
Old Aug 21, 2005 | 09:09 AM
dome's Avatar
Default Re: (mrbsponge)
i like wiseco and crower. wiseco comes with coated side skirts.
hoo my gosh
Mar 28, 2008 08:50 AM
spunautosports
Nov 8, 2006 07:37 PM
egvtec
Dec 12, 2005 03:49 PM
andrewasf77
14
Jun 4, 2004 08:43 AM
