help how to improve may 60ft
Old Aug 20, 2005 | 10:23 PM
forcedspeed's Avatar
Default help how to improve may 60ft
Hi guys iam from the philippines, i need some suggestions on how to improve may 60ft time, may set up is an all motor ZC engine non vtec all motor, stock short block, may whp is 142 and may torque is 112. may current time is 13.6 @98mph may 60ft time is 2sec flat iam using a 23x13x8 mt dragtires, hope to get suggestion from you guys thanks a lot
Old Aug 20, 2005 | 10:24 PM
flip1199's Avatar
Default Re: help how to improve may 60ft (forcedspeed)
what are u launching at and how many psi in the slicks?
Old Aug 20, 2005 | 10:27 PM
Default Re: help how to improve may 60ft (flip1199)
Its an all motor set up iam lounching it at 5k, iam using a stock trani 4.25final drive thanks
Old Aug 20, 2005 | 10:37 PM
flip1199's Avatar
how much psi?
Old Aug 21, 2005 | 02:48 AM
10psi sir,when the tires are hot
Old Aug 21, 2005 | 08:00 AM
b19coupe's Avatar
Try upping your launch rpm. 6,000 then 7,000 (if your motor revs that high) . See what effect that has on your 60's. You can also lower your tire pressure. My best 60's to date have been at 8.5 psi.
Old Aug 21, 2005 | 07:41 PM
BoOsTiN Dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcedspeed &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys iam from the philippines, i need some suggestions on how to improve may 60ft time, may set up is an all motor ZC engine non vtec all motor, stock short block, may whp is 142 and may torque is 112. may current time is 13.6 @98mph may 60ft time is 2sec flat iam using a 23x13x8 mt dragtires, hope to get suggestion from you guys thanks a lot </TD></TR></TABLE>
Damn you hit a 13.6 with that little power? How much does the car weigh?
Old Aug 21, 2005 | 08:34 PM
Default Re: help how to improve may 60ft (tRaCeBuStA)
thanks a lot guys ill try that thanks. may car is an all steel eg hatch i just took of the interior and the dashbord thanks guys
Old Aug 21, 2005 | 08:41 PM
damn thats like a stock LS motor hitting 13.6s on slicks
Old Aug 21, 2005 | 09:04 PM
dunkd's Avatar
took out the dash?? any pics?
Old Aug 21, 2005 | 09:13 PM
T4eg's Avatar
Default Re: (dunkd)
i think a 23 8 13 is too big of tire for that. but thats just me. Id look into 20 8 14's
Old Aug 21, 2005 | 09:17 PM
buck02's Avatar
Default Re: (T4eg)
a set of my limit straps they garrenteed to work
tapboyzlilj
May 21, 2007 09:17 PM
forcedspeed
Sep 17, 2005 09:46 PM
rocketfuelcerx
12
Mar 16, 2005 08:31 PM
dragaholic
Dec 21, 2004 08:35 AM
garados
Apr 28, 2003 05:55 AM
