JDM ITR non hid's
Old Aug 20, 2005 | 08:27 PM
iMPorT_kULtuRe's Avatar
Default JDM ITR non hid's
Does anyone know what lowbeam bulb the JDM ITR headlights run?
Old Aug 20, 2005 | 08:54 PM
Padawan's Avatar
Darth ModerVader
Default Re: JDM ITR non hid's (iMPorT_kULtuRe)
9006 - the same as the USDM lights.
Old Aug 20, 2005 | 09:25 PM
Default Re: JDM ITR non hid's (Padawan)
sorry bro not true. my 9006 is just sitting in the socket. it clearly doesnt fit. the lowbeam socket on the JDM housing, has a clasp to hold the bulb in place like a h3 bulb. is there no one that has JDM ITR non hid headlights in here?
Old Aug 20, 2005 | 09:37 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iMPorT_kULtuRe &raquo;</TD></TR><TR><TD CLASS="quote">sorry bro not true. my 9006 is just sitting in the socket. it clearly doesnt fit. the lowbeam socket on the JDM housing, has a clasp to hold the bulb in place like a h3 bulb. is there no one that has JDM ITR non hid headlights in here?</TD></TR></TABLE>
Yes, it is true. If the 9006 bulbs aren't fitting properly in your housings, then something else is wrong. Are you certain they're halogen housings, and that nothing is missing from them?
Old Aug 20, 2005 | 09:42 PM
yah it doesnt fit. im not missing anything. i pulled the oem hid unit out myself.
anyone else? open for suggestions.
Old Aug 20, 2005 | 09:51 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iMPorT_kULtuRe &raquo;</TD></TR><TR><TD CLASS="quote">yah it doesnt fit. im not missing anything. i pulled the oem hid unit out myself.
anyone else? open for suggestions.</TD></TR></TABLE>
You originally stated that these were non-HID (halogen) housings. Clearly, a halogen bulb is not going to fit properly in an HID housing. The HID versions utilize a D2S HID capsule.
Old Aug 21, 2005 | 02:03 AM
nightrider's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
You originally stated that these were non-HID (halogen) housings. Clearly, a halogen bulb is not going to fit properly in an HID housing. The HID versions utilize a D2S HID capsule. </TD></TR></TABLE>
dude, the original poster just got himself completely confused or something.
Old Aug 21, 2005 | 09:47 AM
{Mineral Grey} ITR's Avatar
Default Re: JDM ITR non hid's (nightrider)
If you look very closely on the headlight housing, the correct bulb number is etched there in each dersired spot!
Old Aug 21, 2005 | 10:03 AM
Yah I did! Im still learning about my DC. I went from a CRX w/ b18, to doing a front end conversion on my DC. What a change. So I wil start over. OK I have
the JDM ITR HID headlights. I had to remove the HID unit from the headlight.
Now there is a clasp that held the D2S capsul in place.OK. It looks like a big h3
housing. Now what I need to know is, since I have completly removed the HID UNIT, can I run a halagen bulb? From what I have been told, is that the HID is only an oem option. So what I get out of that ,is that it ran a halogen before the upgrade. Or is it a completly differant Headlight that is installed for the HID Factory option?
Old Aug 21, 2005 | 10:49 AM
Taristin's Avatar
Completely different headlights from the factory. The lenses are completely different.
Why on earth would you try to make an HID headlight into a nonHID headlight? The HIDs are so much better.
Old Aug 21, 2005 | 11:06 AM
Default Re: (Taristin)
Well the driverside HID unit is burnt. I dont know where to get the JDM OEM HID unit from. So I have to rigg something up so I can have headlights. Till I find the unit somewhere. Make sence now.
Old Aug 21, 2005 | 11:31 AM
cryptikman's Avatar
Default Re: (iMPorT_kULtuRe)
Is it just the bulb? Or is it the ballast? Igniter? You do not necessarily have to get the "JDM OEM HID" unit to make it work.
Old Aug 21, 2005 | 02:36 PM
Crx Jimmy's Avatar
Default Re: (cryptikman)
i have seen a h7 bulb trimmed to fit that housing whether it works well or not im not sure
Old Aug 21, 2005 | 02:38 PM
Crx Jimmy's Avatar
Default Re: (Crx Jimmy)
i have a oem hella ballast from a mercedes, tell me if you want to buy it
Old Aug 21, 2005 | 03:33 PM
nightrider's Avatar
http://www.suvlights.com/
i sourced my ballast from here when it fell off while my brother had my car. they are very helpful and i cannot tell you how good their service was.
Old Aug 21, 2005 | 03:59 PM
Taristin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iMPorT_kULtuRe &raquo;</TD></TR><TR><TD CLASS="quote"> Make sence now. </TD></TR></TABLE>
Ya much clearer.
But is it the bulb, ballast, igniter? What died?
Old Aug 21, 2005 | 04:58 PM
I dont know? I was supposed to have 6000k in both but only one was installed. The other one is all crusty and ****. That one started to smoke. It also makes a buzzing noise when I turn it on. My passenger side works cherry. That one has the new unit in it. This place I baught it from screwed me over probly. It took them over 4 months to get it to me from canada. Then when I got it, they only shipped one headlight. So the one they sent to complete my order is the one that is shitty!
The company is called IMPORT ADRENELIN. If you are planning to buy from them DONT! They lagg and thier customer skills suck *** !
hmongyaj87
Jun 4, 2007 01:01 AM
SoSoxGino
Dec 2, 2003 11:18 PM
CIVIC dude
Mar 1, 2003 11:57 AM
ILOVEGIRLS
Feb 8, 2003 07:31 PM
