60k Maintenance Service Question
Old Aug 20, 2005 | 07:18 PM
RNPoo7's Avatar
Default 60k Maintenance Service Question
Hey guys, I searched this and found a few threads but not exactly what i'm looking for.
First of all, I have a 2000 GSR with 74k right now.
It has been boosted for about 10k.
It kinda slipped my mind to do the 60k service simply because I am always working on the car and didn't really see a need for it since I always do most of the things on their list.
Here's a list of what seems to be the service they do:
Replace Oil Filter
Change Engine Oil
Check All Fluid Levels
Check Tire Pressure
Inspect Front and Rear Brakes
Adjust Parking Brake
Flush Brake System
Replace Brake Fluid
Change Transmission Fluid
Replace Spark Plugs
Replace Distributor Cap and Rotor
Inspect Exhaust System
Inspect Suspension & Steering
Inspect Drive Axles and Boots
Add Fuel Injector Cleaner
Replace Fuel Filter
Replace Air Filter
Adjust Valves
Replace Valve Cover Gasket
Inspect Drive Belts
Road Test Vehicle
2 weeks ago, I replaced the timing belt, water pump, and tensioner. Yah I know it's early to change them, but for some reason my timing belt was beaten to death. I'll upload pics soon.
So I was wondering if you guys think I should still do it, even though I have 74k now. Also, anything that is missing from that list. This is the 60, 90, 120k, etc service.
Thanks in advance.
Pete
Old Aug 20, 2005 | 07:33 PM
Ti3d in's Avatar
Default Re: 60k Maintenance Service Question (RNPoo7)
You should definitely do all that stuff, especially since you're boosted. It'll prevent possibly a lot of headaches in the future, so its a good idea.
Old Aug 20, 2005 | 08:17 PM
Lauj87's Avatar
YES DO IT!!!
Old Aug 20, 2005 | 08:32 PM
RNPoo7's Avatar
Ok cool.
Here's the thing though, I have everything on that list done except for
Now i'm an idiot when it comes to suspension, should I actually go give it to them to inspect teh suspension, axels, and boots? Or should those be ok?
Adjust Valves
Also, I heard it was kinda of an easy job to adjust the valves but just tidious and time consuming. Should I just take it to honda/acura to do that for me?
Lastly,
I inspected my a/c, alternator, and power steering belts and they were all fine when I changed the timing belt.
Is there any other belts that I need to check?
Thanks a lot for the help.
Old Aug 20, 2005 | 08:44 PM
B16CRXT's Avatar
Default Re: (RNPoo7)
When they inspect suspension, they just make sure your bushings arent shredded or shitty. No excessive noise or anythign from it... for the steering, just take it to a tire shop and have them do an alignment.
Old Aug 20, 2005 | 11:21 PM
vice versa's Avatar
Default Re: (B16CRXT)
if u drove a ford, u would of needed a new car by now.
haha.
Old Aug 20, 2005 | 11:24 PM
DAguyLS's Avatar
the valves aren't that time consuming to adjust
if it's your first time it may take a couple hours....but everytime after that is half the time.
Old Aug 21, 2005 | 10:29 AM
RNPoo7's Avatar
Anyone have a write up on how to adjust the valves?
Old Aug 21, 2005 | 01:50 PM
DAguyLS's Avatar
This is for a GSR, but the specs for your valve lash are under your hood (assuming you have a stock hood) and the rest is the same.
This is a great write up btw
http://www.c-speedracing.com/h...t.php
Old Aug 21, 2005 | 01:58 PM
XyKo
Guest
Posts: n/a
Default Re: (DAguyLS)
This is tough since you did most of the tune-up already. I got my 60k tune-up at the Honda dealer and it cost waaaay cheaper then Acura. Acura charge nearly $600 and the honda people did everything for me with inspection for $250.
Old Aug 21, 2005 | 02:05 PM
RNPoo7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAguyLS &raquo;</TD></TR><TR><TD CLASS="quote">This is for a GSR, but the specs for your valve lash are under your hood (assuming you have a stock hood) and the rest is the same.
http://www.c-speedracing.com/h...t.php</TD></TR></TABLE>
Thanks a lot for the link man
MacH
Apr 11, 2008 09:18 AM
trustbuddy
Feb 26, 2003 12:17 PM
GSR_Fan
Jan 3, 2003 08:20 PM
SonicGSR
Oct 9, 2002 08:16 PM
SonicGSR
Oct 9, 2002 07:28 PM
