Need help socketing obd0 ecu for hondata, walkthrough if any?
Old Aug 20, 2005 | 04:34 PM
R6E6I6D's Avatar
Default Need help socketing obd0 ecu for hondata, walkthrough if any?
the title basically says it all but, i got a oldschool stage 3B hondata bluebox, and I need to figure out how to socket my ecu, i got the chips and hookups but cant find a link on hondata.com to do it, if you can send me a link or the knowladge id appreciate it.
Old Aug 20, 2005 | 07:41 PM
xenocron's Avatar
Default Re: Need help socketing obd0 ecu for hondata, walkthrough if any? (R6E6I6D)
http://www.pgmfi.org/twiki/bin...pping
There's a decent link to help you out.
Basically you want to desolder the 28 pin socket and the spot labeled CN3 in a PR3/PW0
Old Aug 20, 2005 | 11:49 PM
R6E6I6D's Avatar
Default Re: Need help socketing obd0 ecu for hondata, walkthrough if any? (xenocron)
desolder than solder what?? will i need desoledring braid i havent taken the ecu apart yet,?
Old Aug 21, 2005 | 11:10 AM
xenocron's Avatar
Desolder (or remove the stock chip) the 28 pin spot and then solder back in a socket. Place the 4 pin header for Hondata in the spot labeled CN3.
And read the link...it goes over it all.
Old Aug 22, 2005 | 10:08 AM
R6E6I6D's Avatar
hey thanks a lot man, i really appreciate it you helped me out big time
Old Aug 26, 2005 | 01:27 AM
R6E6I6D's Avatar
is there a way you canhelp me on hooking up launch control to clutch safty switch><<
Old Sep 2, 2005 | 09:49 AM
R6E6I6D's Avatar
anyone now where i can get a basemap loaded up?
Old Sep 2, 2005 | 08:25 PM
xenocron's Avatar
http://www.xenocron.com/bins
i know there is one BRE tuned B16 map up there by J. Davis
As far as a launch control to a clutch safety switch...thats not a feature of BRE as far as i know....LC is built in but anything for a clutch switch
Old Sep 2, 2005 | 08:33 PM
2k.civic.si's Avatar
i can make u a bin...and launch controll doesnt need a switch....you can set it up off mph
ThA5oLuTiOn
Engine Management and Tuning
May 19, 2010 12:50 PM
crampinyourstyle
Aug 17, 2006 10:41 AM
projectef
Jul 25, 2006 03:22 AM
