Tranny problem, request info.
Hello all,
It looks like there is a lot of experience here, so I hope someone can diagnose my problem.
On my way back from vacation, my 94 accord started skipping a beat once in a while when pulling long hills. I thought it was a bad plug or wire, so I kept driving. It gradually got worse (luckily I was near home by this time), until it started making a medium pitch whine, kind of like a gear not quite engaged. The transmission was basically out of fluid when I checked (oops).
I re-filled, and the car runs fine in D3, but when it is in D4, and shifts into the highest gear, it makes the noise.
I checked the solenoids, and they clicked when I apply 12 volts, but I'm not sure what else to check.
My question is do I need a complete new tranny, or is there something small I can replace or fix to get the car back on the road?
thanks in advance.
Allen
thanks in advance.
Allen
IF you have not noticed any loss of acceleration, AND the noise when it shifts into od4th starts immediately (rather than waiting for the converter to lock-up), the problem is more related to 4thOD rather than the converter.
The converter can fail in two ways:
1) Stator / Overrunning Clutch fails and converter looses torque multiplication properties (loss of acceleration) and is usually associated with an all-time buzzing noise.
2) Lock-up plate fails to engage. Would be noisy only when applied.
This doesn't sound like what you've got
Either way, you're looking at transmission work
PrecisionH23a
Jun 16, 2003 07:29 AM
