Where is the A/C Compressor Clutch Relay located???
Old Aug 20, 2005 | 03:15 PM
95TEG's Avatar
Default Where is the A/C Compressor Clutch Relay located???
Can someone tell me where the A/C compressor clutch relay is located on a 95 Integra LS? I cant find the damn thing. Thanks.
Old Aug 20, 2005 | 06:36 PM
RaceCity_USA's Avatar
Banned
Default Re: Where is the A/C Compressor Clutch Relay located??? (95TEG)
Well, Rob, I have a 94 GSR, and on it, the compressor clutch relay is located in front of the A/C condensor, behind the front bumper cover. (No wonder you can't find it!) If you reach up through the lower bumper cover opening, behind the bumper brace, you'll find it right behind the 'e' in the "Integra" imprint on the bumper. There are actually 2 relays located together there. The A/C compressor relay is the one on the drivers side (on the right facing the rear of the car).
Hope this helps,
Dave
Old Aug 21, 2005 | 05:35 PM
95TEG's Avatar
Default Re: Where is the A/C Compressor Clutch Relay located??? (RaceCity_USA)
Hey thanks Dave. So the one on the right is for the compressor clutch or the compressor? Just want to make sure I get the right one. Thanks again.
Rob
Old Aug 21, 2005 | 06:37 PM
Banned
The A/C compressor relay is the one on the drivers side of the car. When you are reaching up under the front bumper and feel the two relays, it will be the one on your right.
Dave
Old Apr 24, 2016 | 04:07 PM
Scott Forbes's Avatar
96project
Jul 30, 2011 04:39 PM
hondaZvic
Sep 22, 2009 06:04 PM
DB1_559
May 18, 2009 08:55 PM
turbob16ef
Jan 11, 2006 03:47 PM
