Newb here got a question about my R...??
Old Aug 20, 2005 | 02:31 PM
buddyclub69's Avatar
Default Newb here got a question about my R...??
I am doing a rebuild on my 98 Spec R engine here shortly and I have already purchased a full buddyclub stage IV head package and am looking for pistons now. I was leaning towards some Wiseco 82mm 12.0:1 compression, can I run those on pump gas pretty well with no detonation with a good tune? All info greatly appreciated. Thanks.
Jon
Old Aug 20, 2005 | 03:11 PM
Spids5's Avatar
Don't judge or question
Default Re: Newb here got a question about my R...?? (buddyclub69)
With a good tune you should be fine. I ran 11.5:1 on my old b16a2 untuned on 91 octane and it ran fine. It ran a little rich but it never had detonation.
Old Aug 22, 2005 | 11:20 AM
sweet, thanks man. Just was a little concerned about having to run race gas on 12.0:1 compression
Old Aug 22, 2005 | 11:23 AM
typer_696's Avatar
Default Re: (buddyclub69)
You will be able to tell when you have it running or hear a lot of pinging from the engine if you need a higher octane rating. You should be fine on premium
Old Aug 22, 2005 | 11:35 AM
Dave_B's Avatar
Default Re: (typer_696)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_696 &raquo;</TD></TR><TR><TD CLASS="quote">You will be able to tell when you have it running or hear a lot of pinging from the engine if you need a higher octane rating. You should be fine on premium</TD></TR></TABLE>
Pinging comes from lower octane fuel. Detonation is different.
I don't think you will need to run race gas but you will probably need a stand alone EMS for tuning. Tuning will be critical for the setup. What other mods do you have?
Old Aug 22, 2005 | 11:44 AM
LUCKY CHARMS's Avatar
i'm planning on doing the same cam's, do i need to uprate fuel pump & injectors and what ecu are you going to run as there does'nt seem to be a buddy club one available at the moment, if theres any info you can give me it would be much appreciated
Old Aug 22, 2005 | 11:50 AM
nsxtasy's Avatar
H-T Order of Merit
Jon,
Here's a tip for you. When you start a topic, it helps to make the title specific, so people know what it's about when they're looking at the list of titles, and can decide whether or not to open it based on what it's about.
For example, EVERY topic here has a question about an ITR. So "Newb here got a question about my R...??" doesn't really say anything about your topic. But if your title said "Gas and Pistons for Buddyclub Head Package", people would know exactly what your question is about. Those who can answer will be more likely to open the topic and do so, while those who can't, will know enough to skip over it.
Thanks, and good luck with your rebuild.
Ken
Old Aug 22, 2005 | 12:02 PM
Dave_B's Avatar
And the resourceful Ken has spoken. He's got a point though.
Old Aug 23, 2005 | 11:19 AM
Sorry guys, will make point clear next time, I am going to go full buddyclub stage IV head , toda cam gears, mugen head gasket, crower 83mm stroker kit, twm individual throttle bodies, i already have the AEM EMS ready for install, i was just wondering if the 12.0:1 compression wold be to much for 93 octane, thanks for all you guys help, ill keep you all posted on the build! Should be done in less than 1 month, And the motor is a 98 Spec R B18C
jon
THC07
May 29, 2007 07:26 PM
99hondacura
Feb 6, 2007 09:30 PM
kornerk12
11
Aug 8, 2006 07:53 AM
Steak84SS
Apr 12, 2006 08:14 PM
hondaracin24
Mar 16, 2005 08:24 AM
