Suspension
i know the search function is down but i believe the majority of people on here seem to recommend the ground control/ with koni yellows. you can get custom spring rates with the ground controls. you can also have the koni yellows custom valved. are you going for stock replacements? if so, then the kyb gr2s are pretty much a stock replacement (they are slightly firmer then stock). so what are you planning to do to your car?
