Suspension & Brakes Theory, alignment, spring rates....
snapped head 14mm lower shock bolt...help plz
Old Aug 20, 2005 | 07:44 AM
Jay Blazed's Avatar
Default snapped head 14mm lower shock bolt...help plz
umm yea while i was trying to get those lower shock bolts loose i managed to snap one of the heads right off
is my car a big paperweight now ... ?
Old Aug 20, 2005 | 08:26 AM
PIC Performance's Avatar
Default Re: snapped head 14mm lower shock bolt...help plz (Jay Blazed)
No! You have the choice of cutting the bolt out and removing it by fragments, OR switching out the LCA + shock as one piece, assuming you can successfully remove the remaining 2 bolts.
Old Aug 20, 2005 | 08:34 AM
Jay Blazed's Avatar
i am getting ready to cut off the shock fork w/ the threads
using a dremel and a cutoff tool
if i did cut that fork off wouldnt the rest of the bolt just slide out...considering how the head is snapped off
thanx
Old Aug 20, 2005 | 08:56 AM
Asselin's Avatar
The bolt won't just slide out easily, sure you can cut the fork off, but the bolt is actually seized inside the bushing. Penetrating oil and a hammer and a punch will be your best bet. ?
Old Aug 20, 2005 | 09:02 AM
Jay Blazed's Avatar
i hope i can cut the fork.........
anyone know where i can replace those bolts???
Old Aug 20, 2005 | 09:49 AM
Default Re: (Jay Blazed)
I used this cool hand-held rotary saw for the shock fork. I was told a dremel could not cut it.
Old Aug 20, 2005 | 10:12 AM
Jay Blazed's Avatar
its goin to the shop
Old Aug 20, 2005 | 02:16 PM
Asselin's Avatar
My dad has this big *** torch, and made the fork red hot and crumbled off. I was sad.
Old Aug 20, 2005 | 05:48 PM
civic_speed99's Avatar
Torch it or cut off the nut that is on it. Then take the other bolt to a hardware store and get another one cheap or go to the dealer and pay 10x more.
Old Aug 20, 2005 | 08:09 PM
chinese acrobat's Avatar
Ur best bet is to cut off the fork. Drill out the remains and replace with a bolt and nut unit
Use grade 8.8 and lots of anti-seize
LCA swap to because the bearings are sht.
Old Aug 21, 2005 | 05:52 PM
meanEG's Avatar
Default Re: (chinese acrobat)
heres what you do...
cut the other end of, between the bushing and hub assembly. this will disconnect you from the hub, then tale the other 2 bolts out on t he arm and take it to a press if available. press out eh middle section of the bushing out and then the outer ring in still in the arm. (the middle will seperate and rip the rubber.)
once that is done press out the ring witha socket or what i do is place the arm ina vise and use an air hammer with a chisel bit. place the bit on the metal ring of the bushing nad blast away. usually once you get halfway the bushing will fly out. you will ten havet to remove the bolt from the nut on the hub or break it off the hub witha 17mm and breaker bar or air hammer. then repalce with aregualr nut.
you will have to buy a new bushing from honda and bolt too. really isnt too bad, may take about a 1/2 if you have air and press.
Old Aug 22, 2005 | 10:21 AM
ImportAutoPerformance.com's Avatar
Once you get it out, you will be better off picking up a new set of LCA's rather than pressing new bushings in the factory arms. Hope this helps.
Old Aug 22, 2005 | 11:33 AM
meanEG's Avatar
Default Re: (peteriap)
why would you be better off?
Old Aug 22, 2005 | 05:45 PM
Cut the nut off the shock that way you don't need new bushings, unless it is frozen to the bushing. That happend to me with the rear UCA, I had to torch it off.
Del Sol Man
72
Jun 21, 2006 08:13 AM
EGhatch33
Suspension & Brakes
24
Jan 2, 2006 10:01 AM
M@
May 17, 2005 04:35 PM
Shocka1998LX
Aug 22, 2004 05:11 PM
teg92
Feb 2, 2004 05:21 PM
