Type R rear ebrake bracket question
Old Aug 20, 2005 | 03:07 AM
rough_draft's Avatar
Default Type R rear ebrake bracket question
i just did the 5 lug swap onto my ek. I had disc brakes on the back, not sure if they were gsr or si but my question was that on the Type r rear disc brakes the 2 holes for the ebrake cable are not threaded, compared to my ek disc brakes which were threaded. did you guys just use a 10mm bolt and nut? here is a picture for reference. its number 24.
also does anyone know the part number for that part? (number 24 and 34, the other side). Also does anyone know the part number for the lil stud that the copper pin goes through for the ebake? Like when you put the ebrake cable onto the caliper, then the stud through the ebrake cable, then the copper pin through the stud.
thanks in advance
ryan_1014
Jul 24, 2010 07:38 AM
turboblack2door
Apr 30, 2009 03:18 PM
JLEK
17
Jun 11, 2007 09:58 PM
**DOHC HaTcH**
Mar 21, 2007 12:48 PM
sirsmokesalot
Jul 16, 2006 11:18 AM
