Question about changing wheels
Old Aug 19, 2005 | 08:08 PM
mkazm83's Avatar
Default Question about changing wheels
I had my wheels changed (to the same wheel size) and had my tires rotated. I had the tire shop put glue (inside of the wheel) weights on. Now my car pulls to the passanger side. It did not do this before and I am baffeled by this. The issue is REALLY noticable.
Any idea on what this could be?
**EDIT**Tire pressure is the same give a few PSI
Old Aug 19, 2005 | 08:53 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Question about changing wheels (mkazm83)
Usually when a car pulls to one side, the problem is in the car's alignment, not in the wheels themselves.
I'm not sure why changing wheels and tires would have anything to do with the pulling showing up... unless your new tires had so much better traction that the pulling became more noticeable, and was masked before by the older, worn tires? Or maybe one of your wheels is slightly out of round, but didn't cause pulling when it was on the back, only when it was moved to the front?
If you still have your other set of wheels and tires, you could swap them back on and see if the problem goes away. But if you're saying that you had the wheels changed but still are using the same set of tires, that's not an option (but you could try rotating the tires back to their previous position to see if that makes the problem go away).
I would take the car to a good mechanic with the equipment to do an alignment. Maybe others here have some other ideas of something else you can try first...
Old Aug 19, 2005 | 09:01 PM
mkazm83's Avatar
Default Re: Question about changing wheels (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Usually when a car pulls to one side, the problem is in the car's alignment, not in the wheels themselves.
I would take the car to a good mechanic with the equipment to do an alignment. Maybe others here have some other ideas of something else you can try first...</TD></TR></TABLE>
I had the tires rotated (still have the same tires on)
Old Aug 20, 2005 | 08:19 AM
nsxtasy's Avatar
H-T Order of Merit
Thanks.
As I mentioned, you could try rotating the tires back to their previous positions, to see if that makes the problem go away. But I'm still betting it's the alignment... (Maybe someone else here has some other ideas?)
duwa
Oct 26, 2011 08:19 AM
billc5050
Acura TL, RL & ZDX
Jun 13, 2011 08:23 AM
ServerMechanic
Jan 29, 2009 02:47 PM
ESCALVANTE
14
Apr 29, 2002 05:29 PM
99civic_exSB
Apr 24, 2002 04:42 PM
