b18a swap --- Mount issue
Old Aug 19, 2005 | 01:23 PM
B18aHatch's Avatar
Default b18a swap --- Mount issue
ok guys, so i just droped a b18a in my 89 crx. i have a problume. my driver side axles is scrooed up. it goes from the tranny into the half shaft bolted to the block. then my axle goes at an angle backwardto the hub. now my question is what mount did people use for the dirver side engine mount? i just used the LS mount that was on the motor... is this the wrong mount to use? cuz somthing is obvously wrong.... if anyone remembers if you use the crx mount or what please let me know.. thanks
Old Aug 19, 2005 | 02:06 PM
Mr_ET's Avatar
Default Re: b18a swap --- Mount issue (B18aHatch)
you used a mount kit right?
Old Aug 19, 2005 | 02:21 PM
B18aHatch's Avatar
of course i use a mount kit.
Old Aug 19, 2005 | 02:30 PM
tangerinebeast's Avatar
just get some hasports or cut the stock mounts and move them to where your axle is lined up straight
Old Aug 19, 2005 | 04:52 PM
boostedSI90hatch's Avatar
Banned
Default Re: (tangerinebeast)
he said he used an ls mount. you need a kit (hasport etc)
Old Aug 19, 2005 | 06:50 PM
B18aHatch's Avatar
ok i think there is some confusion goin on. I have the mount kit. with the three rubber mounts needed for the swap. i am talkng about the mount that is attached to the engine on the drivers side, under the timming belt with the 2 holes in it. that is the mount i am talkng about.
90redintegra
Dec 8, 2006 06:17 AM
sloweredcivic
May 15, 2005 09:01 PM
cubancrx
Apr 5, 2004 11:38 AM
dutchman5
Feb 6, 2003 12:48 AM
