Will NEON SRT-4 injectors fit my b18c1??????
Old Aug 19, 2005 | 09:53 AM
ebp_dc2's Avatar
Default Will NEON SRT-4 injectors fit my b18c1??????
Just wondering...upgrading my injectors and found a good deal on these....will they fit my car...i know ill prolly have to modify the clip, but i mean will they physically fit?..
also are these peak and hold or saturated???
Old Aug 19, 2005 | 10:22 AM
TheShodan's Avatar
Moderator
Default Re: Will NEON SRT-4 injectors fit my b18c1?????? (ebp_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebp_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering...upgrading my injectors and found a good deal on these....will they fit my car...i know ill prolly have to modify the clip, but i mean will they physically fit?..
also are these peak and hold or saturated???</TD></TR></TABLE>
No. Though not that we haven't tried, the spray pattern and use of the A853 Motor is VERY different from the honda, especially with the piston design of the A853 at TDC.
Try your luck if you must, but there are ton of other applications that will more than likely give you the results you need. tuning them will be the hard part.
Old Aug 19, 2005 | 10:31 AM
ebp_dc2's Avatar
up for more info!
Old Aug 19, 2005 | 12:15 PM
ebp_dc2's Avatar
up help me out here!
Old Aug 19, 2005 | 12:19 PM
done's Avatar
Default Re: Will NEON SRT-4 injectors fit my b18c1?????? (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">
Try your luck if you must, but there are ton of other applications that will more than likely give you the results you need. tuning them will be the hard part.</TD></TR></TABLE>
Old Aug 19, 2005 | 12:46 PM
Urban Camo's Avatar
Default Re: Will NEON SRT-4 injectors fit my b18c1?????? (Jordo@KAP)
I have tried to run the 04 srt-4 mopar upgrade injectors the are "555" i had to tune them in as 450cc they flow like 450s on a honda, they also did no fit very well they fit but i kept blowing the top o-ring out on my injectors. the fitment is not 100% i personally would not do it again. I would shy away from these injectors but if you want to put them in Pm me with how much your good deal is cause i have a set i will see if i can beat the price
Old Aug 19, 2005 | 12:57 PM
ITSME4G63's Avatar
use dsm 450's, you can find them cheap on ebay or dsmtrader.
alperx
Mar 6, 2013 12:03 PM
integrx
Dec 4, 2003 12:57 AM
SiRkid
Aug 24, 2002 07:20 PM
vtec-outlaw
Dec 13, 2001 02:30 PM
