S*@TY LOWERING KIT
Old Feb 23, 2002 | 04:50 PM
yellowbuffalo's Avatar
Default S*@TY LOWERING KIT
I bought the Eibach Pro-Kit and had Acura Install them because I dont have any local shops around me to install the springs. SO when I got the car back the front was higher than the back why?
Can someone tell me why the front looks higher than the back?
[Modified by slipknot23, 2:28 AM 2/24/2002]
Old Feb 23, 2002 | 04:54 PM
Just2Fast's Avatar
Default Re: S*@TY LOWERING KIT (slipknot23)
Acura installed them backwards.
Old Feb 23, 2002 | 04:59 PM
Default Re: S*@TY LOWERING KIT (Just2Fast)
you think Just 2 fast? I think your right. If they did install tthem backwards would this hurt anything?
[Modified by slipknot23, 2:00 AM 2/24/2002]
Old Feb 23, 2002 | 05:52 PM
JimmieD's Avatar
yu need to switch them around if they are on backwards. jack up your car and look for the part numbers on the springs. it should have a 4xxxxnumber with a f or r after it. f=front, r=rear. or it might even just hvae numberswhich you will hvae to cross reference to the eibach intructions.
Old Feb 23, 2002 | 07:03 PM
Default Re: S*@TY LOWERING KIT (Phil DeVtec)
Will this ruin my Suspension of my car?
Old Feb 23, 2002 | 07:07 PM
Eskram's Avatar
If it's truly installed backwards, take it back and have them do it correctly. There is a reason there are different front/rear springs.
Old Feb 23, 2002 | 07:39 PM
JimmieD's Avatar
see if it is wrong!!!! if it is than change it!!!!! you should not have anymore questions
Old Feb 23, 2002 | 07:43 PM
Stephen's Avatar
The front was higher than the back?
The front springs are longer than the rears, and the fender gap is larger on front vs. the back. This is normal. If they were installed backwards, the front would be lower.
Many cars look higher up front because of the difference in fenderwell sizes. If it's really different something's wrong. Being <1" different is normal.
Old Feb 23, 2002 | 07:46 PM
non-VTEC's Avatar
i dont think it's physically possible to put the front springs on the rear.......there shapped diffrently and diffrent lengths......you couldent compress the front springs ontot he rear shocks without binding the coils.
when you say the front is higher than the back by how much?
and just to let everyone know the front wheel well fender is larger/taller than the rear so it may seem like the front is higher but it's really the way the wheel wells are shapped.
Old Feb 23, 2002 | 10:19 PM
IN VTEC's Avatar
Just look at the springs as is, and the front springs should have thicker coils, and the rears should have thinner coils.
Old Feb 23, 2002 | 10:48 PM
TurbothisLS's Avatar
Default Re: S*@TY LOWERING KIT (IN VTEC)
i just installed my eibach prokit on friday and the front fender gap is larger than the rear. I thought I put them on backwards too, but now that i look at it, the thicker coils are in the front and I'm sure i didn't screw up. The car looks even in height all the way around. Wait for the springs to settle. should take 1 week. I've installed several sets of springs on my 2 cars and other people's cars and it's pretty hard to put the front on the back and the vice versa.
Old Feb 24, 2002 | 01:05 AM
vteg's Avatar
New User
To be certain check the numbers on the springs. Make sure F is in the front and R is in the rear. Also write down the part number and check it out online. When I got my sportlines, the shop ordered a set for a g2 teg. They installed on the car, but the rear was higher than stock I think(I was changing from another lowering spring), and would not compress. I did not know that the shop ordered the wrong set until I contacted Eibach, and they told me to check for the F and R. When I checked the part number, that was when I found the problem. The shop fixed the mistake.
Old Feb 24, 2002 | 07:09 AM
Default Re: S*@TY LOWERING KIT (vteg)
if the springs are in backwards, wouldn't the back be a lot higher than the front? the front is supposed to be thicker coils and thus the decreased in weight in the back would make the back a lot higher and the front a lot lower. I don't have any "F" or "R" on my springs. The part number is like 4020.something. let me know because i have the same problem of the front having more gap than the rear.
Old Feb 24, 2002 | 07:40 AM
team solo oxymoron racing's Avatar
New User
that was the first kit i bought and after talking to several shops one told me to remove the bump stops another said to buy the legacy springs to lower the front more and another said to cut them. I went my own way and paid $250 for some weapon r coilovers to set my own suspension.
Old Feb 24, 2002 | 10:34 AM
1phatGSR's Avatar
Default Re: S*@TY LOWERING KIT (team solo oxymoron racing)
that is normal for eibach springs the front is alway higher than the back..evently is will sag and look even...
Old Feb 24, 2002 | 11:40 AM
Nighthawk GS-R's Avatar
New User
Default Re: S*@TY LOWERING KIT (1phatGSR)
yeah they prolly need to settle thats all
Old Feb 24, 2002 | 11:52 AM
vteg's Avatar
New User
The part number for pro-kit on a g3 is 4020.140
Take a pic. My sportlines seem slightly higher in the front than in the back. You have to consider that the wheel wells are not cut the same in the front and back, so a visual does not do much.
Old Feb 25, 2002 | 10:01 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
My car was higher in back than in front on stock suspension. After installing H&R Sports the back end still sat just a bit higher, so I pulled my rear shocks and brought the Koni spring perches down to the lower level (15mm lower) and now it's all even.
Old Feb 25, 2002 | 11:48 AM
WOTTEG's Avatar
Default Re: S*@TY LOWERING KIT (Stephen)
I agree, what you describe is to be expected because of what Stephen explained.
Old Feb 25, 2002 | 11:56 AM
VTechie's Avatar
Default Re: S*@TY LOWERING KIT (WOTTEG)
I think it would be pretty funny to see a car that constantly looks like it's accelerating.
Old Feb 25, 2002 | 03:51 PM
threatcon13's Avatar
New User
Default Re: S*@TY LOWERING KIT (VTechie)
by the way..how much did you pay to get the springs installed by acura??
K20 SDN
Honda Civic (2006 - 2015)
Nov 9, 2007 04:57 AM
syrinx
Aug 15, 2002 01:12 PM
redteg1
Jul 31, 2001 12:46 PM
