Main Relay help
Old Aug 19, 2005 | 09:02 AM
CRX_Control's Avatar
Default Main Relay help
When im on the highway going around 4 k rpm , my tachometer jumps around and then my main relay starts to click then the rpm needle goes to zero and I get a check engine light(my vtec light also comes on when the jumping occurs-i have this light for testing purposes so no flaming ). And when i try to give it some gas all it does is nothing.
Old Aug 19, 2005 | 09:56 AM
dogfood's Avatar
Default Re: Main Relay help (CRX_Control)
what code is it throwing, is this an everyday thing or once in a while(some sort of time frame)
Old Aug 19, 2005 | 06:05 PM
EF_9's Avatar
try to re solder every point on your relay this what happened to me
Old Aug 19, 2005 | 08:23 PM
Synth124's Avatar
Default Re: (EF_9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_9 &raquo;</TD></TR><TR><TD CLASS="quote">try to re solder every point on your relay this what happened to me </TD></TR></TABLE>
Yeah, or, just replace it with a new one from majestichonda.com for under $45.
Old Aug 20, 2005 | 06:20 AM
Default Re: (Synth124)
I replaced my relay last year and when this problem started to occur i used my old one which seemed to be working fine but that didnt work either and it was still the same problem. There are no codes when this happens although the light does come on when the problem occurs. Any help will be great. I heard this could also be your ground on the thermostat , i am allso thinking of getting a new fuel pump for it.
Old Aug 25, 2005 | 05:58 AM
dogfood's Avatar
Default Re: (CRX_Control)
I wouldn't just throw a fuel pump at it, because you are going to be pissed when you go through the hassle of dropping the tank and changing the pump and that doesn't fix the problem
Old Aug 25, 2005 | 06:57 AM
Duane_in_Japan's Avatar
I think that all the symptoms are incidental to the root cause of your engine dying, you are going to need some testing to see if you are loosing fuel pressure first, then hook up a test light where you can see it and monitor lose of spark next. It could be several different reasons why your car is dying. But lts start there.
Slomo_civic
Feb 12, 2008 06:36 PM
DeviousCTR
Jun 28, 2006 03:43 PM
wilrock
Oct 18, 2004 08:44 PM
dirtyrotten
Jun 22, 2004 03:08 PM
