Ignition Timing is jumping 20 degress
Old Aug 19, 2005 | 08:45 AM
SSS2000's Avatar
Default Ignition Timing is jumping 20 degress
I'm having problems with my turbocharged LS, using AEM EMS for fuel management. The car has been acting funny when reving above 5k rpm's for a couple weeks, then the problem sterted getting worse. After about 30 minutes of freeway driving, the car would not want to accelerate, when I stepped on the gas the car would just bog down and stall if I took it out of gear. It stalled yesterday and I couldn't get it to start back up, hooked up my laptop and noticed very lean AFR's...I added fuel until I could get it to idle, the idle was very rough and my timing was jumping from 5 to 26 degrees.
Replaced plugs, plug wires, map sensor, what could be my problem?
Old Aug 19, 2005 | 10:21 AM
SSS2000's Avatar
Default Re: Ignition Timing is jumping 20 degress (MilanoRedLST)
I'm getting the ignition timing reading from my laptop hooked up to the AEM...could this be crank angle sensor, distributor?
drvfast
Engine Management and Tuning
May 27, 2010 09:31 PM
drvfast
May 10, 2010 11:16 AM
ek9t72
Jul 7, 2007 10:38 PM
SSS2000
Aug 19, 2005 01:03 PM
