Will 99-00 Si axles work?
Old Feb 23, 2002 | 03:50 PM
Eggman's Avatar
Default Will 99-00 Si axles work?
Can I use 99/00 Si axles and intermediate shaft for a b-series swap in a EF? i know i can use the 94+ integra ones but are these the same?
tia
Old Feb 24, 2002 | 09:49 AM
Eggman's Avatar
Default Re: Will 99-00 Si axles work? (Eggman)
Old Feb 24, 2002 | 09:52 AM
.MilanoRex's Avatar
I am the walrus koo koo kachoo
Old Feb 24, 2002 | 09:56 AM
SiR Kid's Avatar
New User
Default Re: Will 99-00 Si axles work? (crXtreme)
Let's see.... b16a.... B18c... Same transmission housing... same block plus 9mm deck height...
You make the call.
Old Feb 24, 2002 | 10:15 AM
Eggman's Avatar
Default Re: Will 99-00 Si axles work? (SiR Kid)
well, if the ek's are wider than the ef's then i'll have a problem. or if the spines on the knuckles are different then i'll have a problem. i'm using a cable tranny too.
Old Feb 24, 2002 | 10:18 AM
SiR Kid's Avatar
New User
BUT you just said that 94+ integ axles work right?
I was comparing an Si to the Integra, not an EF to a EK.
Old Feb 24, 2002 | 10:27 AM
TypeR0207's Avatar
If you run the '99-'00 Si, '94+ GS-R, or '97-'01 Type R intermediate shaft, then YES, you can run any of those same models axles. You will just have to do the little part where you remove the hub spacer, just like you would for the '90-'93 Teg axles.
I bought Si axles and intermediate shaft because they are newer, and more readily available.
Old Feb 24, 2002 | 09:18 PM
Eggman's Avatar
well, DC and EK suspension is different. so i thought knuckles/axles might be too.
Old Feb 24, 2002 | 09:20 PM
Eggman's Avatar
Default Re: Will 99-00 Si axles work? (TypeR0207)
cool, thanks for the reassurance. i'm gonna try to pick them up. newer design usually is for the better and yeah peeps got replacement axles laying around all over for the newer cars...thanks.
jdmallmotorhatch
Oct 28, 2008 09:57 AM
davenport517
Nov 8, 2007 04:33 PM
builthatch
Apr 19, 2007 05:54 PM
Eggman
Feb 24, 2002 07:16 PM
Eggman
Feb 24, 2002 03:29 PM
