upgrade help d16z6
hey everyone wondering what other upgrades i can do with my car....this is what i have so far.....
88 civic dx hatchback
converted to mpfi
d16z6 sohc vtec swap
converted obd0-obd1
p28 chipped ecu
si front seats
short shifter
si cluster
si rims w/hanook tires
laurel blue paint job
tokico blues
skunk2 coilovers
aem short ram intake
skunk2 exhaust
dc 421 header
what to do next????? need other folks advice....
converted to mpfi
converted obd0-obd1
p28 chipped ecu
si front seats
short shifter
si cluster
tokico blues
skunk2 coilovers
skunk2 exhaust
dc 421 header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wallacecrx »</TD></TR><TR><TD CLASS="quote">turbo
oops forgot to mention im not planning to go turbo...just want all engine....what else can i do???
</TD></TR></TABLE>oops forgot to mention im not planning to go turbo...just want all engine....what else can i do???
the basics...
1st clutch
2nd hmm cam?
3rd maybe a full exhaust or some zc pistons for high comp (i've HEARD of a guy running low/high 14/15s with camshaft, adv timing and zc pistons and such)
1st clutch
2nd hmm cam?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 »</TD></TR><TR><TD CLASS="quote">Zex 59300 camshaft.
Adjustable Cam Gear.
Port and Polish head.
Y8 intake manifold and LS throttle body.</TD></TR></TABLE>
I'm 5/8 of the way there myself (zex cam in other head atm, z6 intake). I'd also suggest the injector upgrade (lude 310's probably), teg/si rear discs & bb/mc, and the accord wagon/itr caliper upgrade on 10.3" front discs.
Besides that...I would save the rest for a new SI or at least a b-series if you're going NA.
he has it down^^
make sure you do some serious head work, you can get ALOT of horspower from headwork alone.
after headwork, get some zc pistons, then upgrade drivetrain(clutch), 100shot, PnP the y8 mani along with the header of your choice, and also bore out the tb, then have the plenum of the im tapered and port-matched. all that should give you some good results.
o, and some weight reduction as well as tires could help too.
-Jose
he has it down^^
-Jose
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HdA1T6CzH6 »</TD></TR><TR><TD CLASS="quote">
oops forgot to mention im not planning to go turbo...just want all engine....what else can i do???</TD></TR></TABLE>
The 100 Shot is out of the question if he wants all motor.
I heard LS rods fit into the D series blocks, or just buy forged ones.
Some more:
Balance Crankshaft (rotating Assembly)
Valve Springs
Valve Retainers
Rev it to 9k.
Some more:
Valve Springs
Valve Retainers
Rev it to 9k.
