Synthethic oil? Redline or AMSoil or etc...
Old Feb 23, 2002 | 01:53 PM
Renegade's Avatar
Default Synthethic oil? Redline or AMSoil or etc...
I have always used Redline but when I went to buy some more today at my local Speed Merchant they told me they will be phasing out the Redline and that AMSoil was better because it has a much higher thermal breaking point,(you know what I mean, it basically can take more heat before the oil start to break down). So I am curious.
Is AMSoil good oil, or should I stick to Redline, OR should I just use synthetics like Castrol or Mobil 1.
Redline and AMSoil cost about $7 a quart and castrol and Mobil are about $3-4/quart.
I am not worried about price, mostly thinking that I may be overdoing it by using Redline when I can get the same result with Castrol or Mobil, also curious if anyone has used AMSoil....
Old Feb 23, 2002 | 02:05 PM
i 4's Avatar
i 4
Default Re: Synthethic oil? Redline or AMSoil or etc... (98401R)
give Royal Purple a try. My R ran alot cooler and felt stronger when i started using it.
Old Feb 23, 2002 | 02:07 PM
nsxtcjr's Avatar
New User
Oil is sort of like religion - it's a matter of whose marketing material you believe.
I believe that 100 percent synthetic oil is worth paying $3-4 per quart for, because it flows better at cold temperatures and it's more resistant to breakdown at high temps.
I believe that Mobil 1 is as good as any other synthetic oil on the market, and that it's not worth paying more than that for some specialty brand.
Your religion may be different from mine.
Old Feb 23, 2002 | 02:14 PM
Flux's Avatar
Default Re: Synthethic oil? Redline or AMSoil or etc... (nsxtcjr)
Some info when I asked about Amsoil in the competition forum...
https://honda-tech.com/zerothread?id=120924
Use search and you will find a ton of stuff about oil.
I'm a member of the Mobile 1 religion.
Old Feb 23, 2002 | 02:36 PM
BoroDB8's Avatar
From: Waipahu, HI and Irvine, CA, best of both worlds, USA
Default Re: Synthethic oil? Redline or AMSoil or etc... (Flux)
i read about amsoil being the ****, but i just use mobil1
Old Feb 23, 2002 | 04:42 PM
AoiGSR's Avatar
25 Year Member
Default Re: Synthethic oil? Redline or AMSoil or etc... (boroDC2)
NEO synthetic supposedly is good. I saw the results after opening an ITR engine and dayum, it was clean in there
-Aoib0t, who corntemplates about NEO in the future.
Old Feb 23, 2002 | 04:56 PM
ImportReview
Guest
Posts: n/a
Default Re: Synthethic oil? Redline or AMSoil or etc... (AoiB0t)
Leading Edge oil.
Without a doubt. Dyno proven over 100 times.
Destroys amsoil, or redline.
Come over for test. If it isn't better, you don't pay.
Jeff
Old Feb 23, 2002 | 10:48 PM
mafay2's Avatar
New User
Default Re: Synthethic oil? Redline or AMSoil or etc... (ImportReview)
Where can I find more info on the NEO oil?
Old Feb 24, 2002 | 09:10 AM
AoiGSR's Avatar
25 Year Member
Default Re: Synthethic oil? Redline or AMSoil or etc... (mafay2)
http://www.neosyntheticoil.com/
http://www.neosyntheticoil.com/where.htm
locations to get.
-Aoib0t, who hopes that helped.
Old Feb 24, 2002 | 09:55 AM
Renegade's Avatar
what is the price on the "leading edge oil"? Is it worth for a street car with some Auto-X. I have not Autox yet, but planning on it soon.
Old Feb 24, 2002 | 04:49 PM
ImportReview
Guest
Posts: n/a
Leading Edge oil ranges from $595 a quart, to $9 a quart.
It destroys NEO.
Come over and dyno NEO VS it..
NEo will get handed.
I got a falex machine too...I bet the LE takes 3x more weight also...
Jeff
Old Feb 24, 2002 | 05:17 PM
mafay2's Avatar
New User
$595 a quart? That's OK, I don't have a F-1 engine, I will stick with those cheaper oil I guess!!
V-Thang
Acura TL, RL & ZDX
Jan 9, 2004 11:04 AM
sracing
Aug 15, 2003 03:11 PM
blkbeast
May 28, 2003 10:48 PM
99 HXagon
21
Jul 26, 2002 06:28 AM
hondacivic4g
Apr 20, 2002 09:21 AM
