throttle body sticking?
Old Aug 18, 2005 | 05:10 PM
2kEM1ebp's Avatar
Default throttle body sticking?
i jsut put a bored throttle body on my integra ls, and its sticking all i have to do is lightly touch the gas and then when the clutch engages it revs around 3k I have to pull the accelerator up from the underneth with my shoe to get it to drop. Any idea how to fix this, it cam with the throttle pully and spring attached and it was used, I have my old throttle body, can the pully and spring be transfered over? Any help would be great.
Ryan
Old Aug 18, 2005 | 09:23 PM
naoandlata's Avatar
Default Re: throttle body sticking? (95b18teg)
I guess there's gunk left over in the throttle body. Try cleaning the throttle body with some throttle body cleaner. I had stick acclerator when I started up the car but after cleaning it, its gone
Old Aug 20, 2005 | 02:51 AM
i_kick_turtles's Avatar
Default Re: throttle body sticking? (naoandlata)
i had an accord that was doing this. i think the throttle bodies are about the same so here it goes:
behind the throttle rotor there is a spring. on the end of that spring the wire bends into a hook. on the trottlebody there is a round piece of metal sticking out just the right size for the hook. put the hook on that piece of metal.
Old Aug 20, 2005 | 03:28 AM
tianporn's Avatar
Default Re: throttle body sticking? (I R Tylor)
Have you played with your throttle cable? You may find you may have set i too tight
FATninja19
Jun 26, 2006 10:51 PM
turbo Si
May 30, 2003 04:05 AM
