oil leak under load
Old Aug 18, 2005 | 02:09 PM
geoman91's Avatar
Default oil leak under load
95 civic d16z6 engine with 271,000 miles , good compression, when i accel to vtec specs, have a oil leak, checked engine and block , where? steamed cleaned engine, where? could it be the oil baffle or the pcv valve, changed the valve and had carbon build up in valve , cleaned and now i have this problem , any answers? help!
Old Aug 18, 2005 | 02:14 PM
ABK's Avatar
ABK
Default Re: oil leak under load (geoman91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geoman91 &raquo;</TD></TR><TR><TD CLASS="quote">95 civic d16z6 engine with 271,000 miles , good compression, when i accel to vtec specs, have a oil leak, checked engine and block , where? steamed cleaned engine, where? could it be the oil baffle or the pcv valve, changed the valve and had carbon build up in valve , cleaned and now i have this problem , any answers? help!</TD></TR></TABLE>
where do you see oil leaking from?
Old Aug 18, 2005 | 03:35 PM
dwnthehatch's Avatar
I know on my ITR motor it was the breather chamber. Ot's the black box your pcv valve goes into.
Old Aug 19, 2005 | 06:52 AM
geoman91's Avatar
Default Re: oil leak under load (dwnthehatch)
is there a way to bypass the breather, oil baffle. should i replace, or what. new to honda engines, why the oil baffle? can't find a oil leak nowhere on the car, that could result in approx. 2 qts in a short time, can the baffle release that volume. if i drive the car like granny, no problems, what kind of fun is that~!
Old Aug 19, 2005 | 07:03 AM
dpkelly's Avatar
You can only remove the oil breather by removing the intake manifold. I know 'cause i tried it last night. Your breather is probably partially clogged with gunky oil like mine. The pcv test where u squeeze the tube that leads to the pcv from the intake manifold is bullsh*t because the breather may be partially clogged. Under high engine load conditions there's more blowby gases which need to vent through the breather otherwise it squirts out from all gaskets.
I plan to poor some gunk degreaser into the breather via the pcv on my next oil change and let it soak. Maybe an engine fogger like deep creep would cure it too. Make sure you get a new O-ring if you remove the breather chamber. Good luck.
Old Aug 19, 2005 | 07:05 AM
dpkelly's Avatar
Default Re: oil leak under load (dpkelly)
On another note, your compression rings might be good but your oil rings might be bad.
Old Aug 19, 2005 | 07:10 AM
dpkelly's Avatar
You can read more about here:
http://72.14.207.104/search?q=...hl=en
The last part of it is important.
Old Aug 19, 2005 | 07:12 AM
Archidictus's Avatar
Unceasing Measure
Do you burn any oil in VTEC (blue smoke, obvious smell, etc.) or are you 100% sure that it's leaking?
Old Aug 19, 2005 | 07:55 AM
dpkelly's Avatar
Default Re: oil leak under load (Archidictus)
Also under high rev conditions, the oil vapor will not go through the oil breather but up to the valve cover and straight into the intake manifold via the bypass hose between the valve cover and the intake. Oil then gets burned in the cylinders. The breather is supposed to separate the oil from the vapors. I hope to remove my intake manifold so i can get to the oil breather and remove and clean it with degreaser.
I guess an oil catcher can be placed on the bypass hose but really is a bandaid to the problem of a gunked up oil breather. I wish the oil breather was easier to get to.
blackeg
Engine Machining & Assembly
20
Sep 28, 2015 07:25 AM
Set O' Nines
Oct 30, 2012 07:49 PM
94VTECoupe
May 26, 2008 04:44 AM
streetcartuner
Dec 18, 2006 06:27 PM
Toda Party
Feb 13, 2002 10:25 PM
