short shifter problem
Old Aug 18, 2005 | 01:47 PM
9hatch6's Avatar
Default short shifter problem
i just installed it. the only problem is the shift linkage hits my exhaust a little bit when its in 5th gear. is that ok? its stock exhaust but when i get new one, will it be ok?
Old Aug 18, 2005 | 02:51 PM
davenavarro1's Avatar
what's the aftermarket shifter? jeez!!
Old Aug 18, 2005 | 03:03 PM
9hatch6's Avatar
Default Re: (davenavarro1)
idk i got it from some kid for free. said it was for a honda. it just hits the pipe not rubb on it. only when i move it to goto 5th. but when its in, its fine
Old Aug 18, 2005 | 03:09 PM
damnraz's Avatar
Default Re: short shifter problem (9hatch6)
the short shifters position of the ball and the end point where you put the bolt in might be a little longer and the linkage is sitting a little bit low, find a short throw shifter made for your setup and maybe that'll solve you're problem. If you get a new exhaust it'll be the same and keep tapping your exhaust.
Old Aug 18, 2005 | 03:11 PM
9hatch6's Avatar
Default Re: short shifter problem (damnraz)
can i live with it tapping a little tho? its honestly not that bad
Old Aug 18, 2005 | 03:19 PM
sprouse's Avatar
i had a civic that i put a shifter on and it done the same thing. Is the part of the shift linkage that is behind the shifter, it should be about two inches long. I just cut of the end of it. thats if that is the part that is hitting it.
Old Aug 18, 2005 | 03:22 PM
Slow EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9hatch6 &raquo;</TD></TR><TR><TD CLASS="quote">i just installed it. the only problem is the shift linkage hits my exhaust a little bit when its in 5th gear. is that ok? its stock exhaust but when i get new one, will it be ok?</TD></TR></TABLE>
I am not sure about how to fix the tapping but as far as getting another exhaust I dont *think* this would make it any better. Chances are the new exhaust will be larger diameter piping and that would create more of a problem. Of course it all depends on the specifics of how things line up etc etc. Just somehting to think about.
Old Aug 18, 2005 | 04:07 PM
9hatch6's Avatar
Default Re: short shifter problem (Slow EJ8)
well its like the shift linkage hitting the piping. but its not much. i mean it doesnt like rub on it u know?
Old Aug 18, 2005 | 05:06 PM
Deemeetree's Avatar
Electrician
Most aftermarket short shifters do hit the exhaust.
Old Aug 18, 2005 | 05:17 PM
junior40er's Avatar
Default Re:
we it can be fixed with new exhaust. I worked as a welder in a shop before and the welder can bend the pipe with a machine to easily fixed that problem. trust me on this. BUT also make sure the shifter is made for your car. IF not then get a new one. A decent one will cost you 40 bucks at kragen and it works good
Dohc.MAD
12
Mar 30, 2005 09:31 AM
erikiksaz1
Mar 28, 2005 01:51 PM
crxzc
Jul 2, 2002 05:09 AM
charjacq
Apr 27, 2002 12:32 PM
Eatvtec97
Apr 22, 2002 11:18 AM
