quick question (mini me)
d16y7 block w/d16y8 head
where can i find some good info on how to put them together
-which head gasket?
-stock head studs?
-which arp head studs?
-timing belt?
-tourqe specs on the head?
thanks for any help
-which head gasket?
-stock head studs?
-timing belt?
thanks for any help
y8 head gasket, arp studs or stock, (y7 and y8 studs are identical), Y7/ Y8 timing belts are identical.
Torque to these steps:
1st: 14ft/ lbs
2nd: 36ft/ lbs
3rd: 49ft/ lbs
4th: repeat 49ft/ lbs
Sequence:
(intake side)
9 3 1 5 7
8 6 2 4 10
(exhust side)
This is from the civic helms manual. Hope it helps.
1st: 14ft/ lbs
2nd: 36ft/ lbs
3rd: 49ft/ lbs
Sequence:
(intake side)
9 3 1 5 7
8 6 2 4 10
(exhust side)
torqueless
Nov 17, 2005 12:33 PM
