Garret housings VS Precision housings
Old Aug 18, 2005 | 09:51 AM
93supercoupe's Avatar
Default Garret housings VS Precision housings
I have a GT35R w/ the .82 precision exhaust housing.The precisions outlet is 2.5 and the Garrets housing is 3 inch.
Do u guys think this is a power loss?
I was told the inside of the Garret housing is also 2.5 inch but then enlarges.The PTE housing is 2.5 straight through.
Is it worth getting the garret housing, or will I not see a difference in power from switching?
Old Aug 18, 2005 | 11:48 AM
Default Re: Garret housings VS Precision housings (93supercoupe)
What, nobody has a reply to this?
Old Aug 18, 2005 | 12:26 PM
Flr Power's Avatar
Need to know also.
Old Aug 18, 2005 | 01:34 PM
Enthalpy's Avatar
I like the design of the garrett Housing because it creates a better transistion from the exducer of the wheel to the ID of a 3" downpipe. the "diverging cone" housing helps extract a bit more turbine efficiency by reducing turbulence on the outlet of the turbine wheel and by creating a slightly lower post turbine pressure.
Old Aug 18, 2005 | 01:36 PM
DRIVENRacing's Avatar
go with the pte housing.. there is no power loss the neck on a gt houing expands into a 3 inch but it also limits your room for dp.. my friend has a gt30r with gt housing and we cant run a big radiator on a ram horn manifold... pte houwer doesnt stretch thse few inches and giuve you more room for fitment..
Old Aug 19, 2005 | 10:53 PM
Default Re: (adSPEED)
so really, U arent going to lose a considerable amount of power by using the PTE housing and the precision housing is only 175 compared to the garrets 300 something.
PTE told me that there is not currently a flange produced for the Garrets 3inch outlet, is that true?
Anyways, Precision it is, thanks guys.
boostedteg909
Jan 28, 2013 04:59 PM
sing
Jun 12, 2009 05:35 PM
MidwestAutoWorks
Jan 15, 2008 07:55 AM
b16hybridsol
Jan 10, 2006 11:36 PM
boosted hybrid
Jan 15, 2003 03:28 PM
