oil in my spark plugs...
Old Aug 18, 2005 | 08:20 AM
Dorksk8tr3's Avatar
Default oil in my spark plugs...
Anyone have an idea why there is oil in the third spark plug houseing? We thought it could be the piston valves or head gasket.. anything I herad about with the head gasket suggested that it would have coolent not oil though....any thoughts...we are going to tear it down and rplace all the valves and all the gaskets anyway and the plugs...pretty much give it a tune up ....thanks in advance.
Old Aug 18, 2005 | 08:27 AM
CBURKE's Avatar
Default Re: oil in my spark plugs... (Dorksk8tr3)
Well it could be the head gasket or it could be your spark plug gasket. I would say Head gasket first. Do a compress test that should tell you.
Old Aug 18, 2005 | 08:42 AM
2kTeg's Avatar
Default Re: oil in my spark plugs... (CBURKE)
compression check.... no need for that its the seal around the top of your valve cover for the spark plugs just get some new ones problem solved its no biggie if you pull your valve cover all you will see what i mean..
Old Aug 18, 2005 | 09:42 AM
CaliforniaHighwayPatrol's Avatar
had the same problem, change your valve cover gasket and spark plug gromets, it is a easy fix
Old Aug 18, 2005 | 09:46 AM
Suck my DX's Avatar
Default Re: (VTEC-Power)
just replace ur spark plug gromets...they tend to harden and compress down after a while..theyre cheap like 2-3 bucks from honda...shouldnt take u longer than 5 minutes...no need to change ur valve cover gasket as long as its not leaking oil from it...i reuse mine all the time...just clean all the oil off before u put it back on so that it seals properly
Acura_DreamiN
Oct 26, 2010 07:23 PM
jdm mini me
10
Mar 25, 2010 09:04 PM
skaternak
Oct 2, 2008 10:32 PM
SuicideSlide
Feb 14, 2007 04:53 AM
jok
Aug 1, 2004 10:43 AM
