anyone getting rid of spoon calipers?
Old Aug 18, 2005 | 07:42 AM
DC2 to AP2's Avatar
Default anyone getting rid of spoon calipers?
im in the market for some... just seeing if any of you guys had some for sale.
https://honda-tech.com/zerothread?id=1343787
Old Aug 18, 2005 | 08:25 AM
Chunty Butt Kevin's Avatar
you have to pay to play
Old Aug 21, 2005 | 10:40 PM
DC2 to AP2's Avatar
Default Re: (Chunty Butt Kevin)
anyone have any used ones or know where i can get them cheaper then 1250 shipped?
Old Aug 21, 2005 | 11:53 PM
Travis10's Avatar
Default Re: (imola-red dc2)
ive heard great things about "stop tech" if you want good brakes i would look past the jdm bling factor,
Old Aug 21, 2005 | 11:58 PM
DC2 to AP2's Avatar
Default Re: (Travis10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Travis10 &raquo;</TD></TR><TR><TD CLASS="quote">ive heard great things about "stop tech" if you want good brakes i would look past the jdm bling factor,</TD></TR></TABLE>
actually ive thought about stoptech alot but im actually looking for a caliper that would fit behind a stock itr wheel. thanks though.
Old Aug 22, 2005 | 03:39 AM
Travis10's Avatar
i never thought about that
Old Aug 22, 2005 | 04:44 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imola-red dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
actually ive thought about stoptech alot but im actually looking for a caliper that would fit behind a stock itr wheel. thanks though.</TD></TR></TABLE>
Do you mind if I ask why you want different calipers? Is this for a track car?
The Spoon calipers were designed for a specific purpose.
They will provide better pedal feel and therefore better perception of modulation, and they will lengthen the life of stock sized brake pads.
If you're having a problem with rotors you are probably going to continue to have that problem because the rotor's heat dissipation will be the same.
For the same amount of money you'd be spending on the Spoon calipers, you could get a big brake kit that used larger sized pads and had bigger rotors. Although the rotors would be more expensive, they would last longer.
Just want to make sure you've thought of all the options and that the Spoon calipers are what you really want after knowing of the options.
Old Aug 22, 2005 | 04:46 AM
.RJ's Avatar
.RJ
Default Re: (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">and they will lengthen the life of stock sized brake pads.
I need to take a pictures of the 2 sets of pads I've gone through already with the new car (LS motor/brakes, stock calipers) - they're both pretty evenly worn through the backing plate, no pad taper here
Old Aug 22, 2005 | 05:03 AM
H-T Order of Merit
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
(LS...brakes, stock calipers) - they're both pretty evenly worn through the backing plate, no pad taper here </TD></TR></TABLE>
Perhaps a braking system with some clamping force would evince some pad taper.
Old Aug 22, 2005 | 05:10 AM
Black R's Avatar
25 Year Member
Perhaps a braking system with some clamping force would evince some pad taper. </TD></TR></TABLE>
.....exactamundo!
no bling = no care
Old Aug 22, 2005 | 05:11 AM
.RJ's Avatar
.RJ
I can brake inside the 3rd marker for T1 @ summit.... I think I have enough force
Old Aug 22, 2005 | 05:18 AM
H-T Order of Merit
Default Re: (.RJ)
I can brake inside the 3rd marker for T1 @ summit.... I think I have enough force </TD></TR></TABLE>
Humph.
Just because you have spherical bearings you're showing off?
Old Aug 22, 2005 | 05:37 AM
.RJ's Avatar
.RJ
I did that with the original, torn up trailing arm bushings.... tail end wagging around and rear tires smoking
BLKCivicPorscheStyle*
33
Apr 11, 2007 12:37 PM
DC2 to AP2
Aug 22, 2005 12:42 PM
darkXtremes
Mar 10, 2005 11:43 AM
01DC2_R
Aug 17, 2004 08:12 PM
JDM Factor
Jun 10, 2004 09:55 AM
