Im A Jackass! blown ignition?
Old Aug 18, 2005 | 07:04 AM
limey156's Avatar
Default Im A Jackass! blown ignition?
so i was doing a compression test on my car today, and there was this unit with it that you hook up to your starter pos. and neg. terminals, hit a button and its supposed to turn the car over without you having to get in the car and do it with the key.
well while hooking it up i accidentally jumped the connection between my starters pos. cable and the body of my starter, and it made a spark. i thought nothing of it and did the comp. test, put it all back together and now my car wont start, my plugs are getting no spark. i checked all the fuses and not a single one blew, and now im stumped.
what else could i have blown? something in my ignitions internals? coil or something? i dont know much about ignitions. its a B16 swapped into an 94 civic. thanks for any help.
CLIFF: no spark checked fuses/plugs. what now-?
Old Aug 18, 2005 | 07:07 AM
dc2legend's Avatar
Default Re: Im A Jackass! blown ignition? (limey156)
Did you check the fuses under the hood?
Old Aug 18, 2005 | 07:23 AM
lodo1's Avatar
Default Re: Im A Jackass! blown ignition? (dc2legend)
if you didnt disconnect the dizzy, mostlikely your ignitor is fried
Old Aug 18, 2005 | 08:33 AM
limey156's Avatar
do you mean the ignition coil or the ignition control module.
also is there anyway to visually tell which one is blown?
thanks!
Old Aug 18, 2005 | 08:43 AM
lodo1's Avatar
Default Re: (limey156)
the ignitor, its inside the dizzy, the peice next to the coil with the 3 visible tabs with wires connected to. pull that out, and see if there are any hot spots on it
Old Aug 18, 2005 | 08:56 AM
SL0WEGG's Avatar
Default Re: (tdocrx)
is the car turning over? if not maybe you forgot to plug that little pin back into the starter. it may sound stupid but you never know
Old Aug 18, 2005 | 11:08 AM
limey156's Avatar
Default Re: (boostedej1)
yeah its cranking over. i also stripped the retaining screw that holds the rotor or whatever in place. damn im ******* up. oh well time to find a new dizzy....
Old Aug 18, 2005 | 12:25 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
don't buy a new dizzy just yet....you can save the rotor problem by cutting a slot in the screw with a piece of a hacksaw blade..then just use a large straight blade screwdriver and turn it slowly, make sure you have a good bite on the screw so you don't strip it again, you can pick up a new ignitor at most auto parts stores for $45-$100 go ahead and paypal me the difference.
Old Aug 22, 2005 | 05:39 AM
limey156's Avatar
hey man
Dec 22, 2010 06:59 AM
gsrkid24
Oct 12, 2009 05:37 AM
oMek
Jan 22, 2005 07:17 PM
the.hamburglar
May 6, 2004 04:29 PM
