Suspension & Brakes Theory, alignment, spring rates....
itr rear sway bar on ek hatch
Old Aug 17, 2005 | 11:40 PM
Danethomp's Avatar
Default itr rear sway bar on ek hatch
i am considering getting an itr rear sway bar for my 99 DX hatch. the only suspension mod i have as of now is neuspeed race springs. i've been searching to get a list together and here's what i've come up with that i'm going to need:
itr rear lca's
itr rear sway bar w/ endlinks
itr rear sway bar bushings
some kind of sub-frame reinforcement (ASR)
anything i need to add or remove from this list? thanks for your help.
Old Aug 18, 2005 | 04:19 AM
Zman15's Avatar
Default Re: itr rear sway bar on ek hatch (90g2ls)
You don't need the rear LCA from an Integra. The 99 DX has the holes for a sway bar.
Also, you could consider the whole kit from ASR.
Latez,
Paul
Old Aug 18, 2005 | 07:01 AM
-_-'s Avatar
-_-
Default Re: itr rear sway bar on ek hatch (Zman15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zman15 &raquo;</TD></TR><TR><TD CLASS="quote">You don't need the rear LCA from an Integra. The 99 DX has the holes for a sway bar.
Latez,
Paul</TD></TR></TABLE>
What he said is true, but I would suggest finding the ITR rear sway bar and endlinks else where. You could easily save $20-$60 depending on the deal you get.
Old Aug 18, 2005 | 08:03 AM
gabebauman's Avatar
You'll need the following:
itr rear sway bar
civic si endlinks
itr rear sway bar bushings and d brackets
some kind of sub-frame reinforcement (ASR) or Beaks kit
good luck
Old Aug 18, 2005 | 10:33 AM
Danethomp's Avatar
thanks for the help.
Old Aug 19, 2005 | 12:22 PM
cheehee's Avatar
does the ASR kit subframe brace serve as a lower tie bar as well? If so, that would make it even more worth it.
HybridIntegra
20
Nov 16, 2004 07:38 PM
defconsc
Mar 21, 2004 09:37 PM
gabspeed
Mar 17, 2004 04:39 AM
