Need help with Skunk 2 manifold installation....
Old Feb 23, 2002 | 10:44 AM
canuck-mx6's Avatar
Default Need help with Skunk 2 manifold installation....
Ok, I have removed the GSR manifold and the black canister thing under it. There is a round vacuum thingy on the right side of the stock manifold, do I have to move that over to the Skunk2 manifold?
Do I really need the ITR TB cable bracket, or can I reuse the one from the GSR TB. I will be using a bored out B16 TB. Can I use the B16 TB sensors without any problems?
Old Feb 23, 2002 | 12:03 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Need help with Skunk 2 manifold installation.... (canuck-mx6)
No, that is the secondary activation unit.
If you're using the GSR t-body, you can reuse the GSR throttle cable and linkage.
If you're using anything else, yes, you need the ITR throttle cable bracket, and LS or ITR throttle cable.
JDMorina
Sep 2, 2015 12:36 AM
aeros
Mar 7, 2011 11:35 AM
YangFlavor
Mar 25, 2010 09:55 AM
1badteg
Dec 19, 2006 06:57 PM
memphiss13
Feb 5, 2003 08:51 PM
