re-routing pcv
Old Feb 23, 2002 | 10:42 AM
Redline130's Avatar
Default re-routing pcv
Has anyone routed their pcv to the exhaust instead of up to the intake manifold? Using the exhaust gas flow instead of the manifold vacuum to pull the crankcase vapors. This is for a race car, so emissions isn't an issue. Any insight is appreciated.
Old Feb 23, 2002 | 05:21 PM
Wes d's Avatar
Default Re: re-routing pcv (cyber13)
I have seen this on a domestic v8. It is supposed to give you a negative pressure in the crankcase and provide a tight ring seal. Guy i talked to said it was critical to get the right inlet angle , going into the exhaust, otherwise you might actually pressurize the crankcase. Also I think they don't use a pcv valve with the setup, it is just a breather line with a oil seporator at the valvecover.
lostforawhile
Jun 22, 2013 09:32 AM
hfraziers
Feb 18, 2010 10:35 PM
94lsboost
Feb 3, 2005 09:08 AM
darkd1gt
Sep 30, 2004 02:45 PM
self_made
Oct 21, 2002 04:06 PM
