Who carries M&W products?
Old Aug 17, 2005 | 10:17 PM
Tony the Tiger's Avatar
Default Who carries M&W products?
I am in the search for M&W parts, both coils and CDI ignitions. I've done some searches (on HT.com, Yahoo, google, etc...) and I cannot find any US vendors. Yet I have seen a handful of guys running M&W products.
Mind sharing where to purchase them?
Thanks
Old Aug 17, 2005 | 10:19 PM
Adi Radoncic's Avatar
On Fire!
Default Re: Who carries M&W products? (Tony the Tiger)
Arturbo/T1 carry M&W!
Old Aug 17, 2005 | 10:27 PM
tony1's Avatar
Default Re: Who carries M&W products? (Adi Raaa)
Old Aug 17, 2005 | 10:42 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Who carries M&W products? (tony1)
We run them, sell them. Just today Tony1 had a car on the dyno that had a MSD digi 6, kept having missfire problems. But the M&W Pro-10 on there and it cleaned it right up!! Made 590whp..
Tony PM me..
art
Old Aug 17, 2005 | 10:46 PM
airshifter's Avatar
do the M&W seem to kill the ignitors like the msd's
Old Aug 18, 2005 | 02:10 AM
BlueShadow's Avatar
Default Re: Who carries M&W products? (Arturbo)
Heya Art,
I might be interested in one of those M&W ignitions systems too. Is there a site where I can read up on it a little? I'm trying to find a suitable ignition upgrade for my 1.9L GSR which I'll be running a T3/T4E 60 trim for now, but in the future I wanna run maybe an SC61 or GT35R. I'll be shooting for 400-500 WHP, so what M&W system would you recommend for my power goals?
Thanks
Old Aug 18, 2005 | 02:13 AM
flip1199's Avatar
Default Re: Who carries M&W products? (BlueShadow)
http://www.mwignitions.com/cdi.html
Old Aug 18, 2005 | 02:15 AM
BlueShadow's Avatar
Default Re: Who carries M&W products? (flip1199)
cool! thanks dood
EDIT: also how hard is it to install one of those CDI systems? like the 2 channel or 4 channel ones? I saw the instructions for them and but I'd have to study it a little to fully understand it. Do you have to install like a sensor or trigger for each coil on the crankshaft or camgear somewhere? Also will these CDI setups still work with CromePRO? I dont think it will.
Old Aug 18, 2005 | 05:36 AM
tony1's Avatar
The single channel system hooks up very similar to a regular msd system. You can use it with a honda computer and you don't have to add any triggers or anything. The Pro-10 is the one you need for a honda ecu. The Pro-12 or Pro-14 are multi channel systems for people with individual coils and aftermarket ecus. The Pro-12 is a 2 channel that you could run wasted spark with and the Pro-14 is a 4 channel. We run the Pro-14 in Allen's car from Honda Heaven with the cbr coils. As far as putting more stress on ignitors, I honestly don't know if it will or not.
Old Aug 18, 2005 | 06:06 AM
BlueShadow's Avatar
Thanks Tony,
I'll look into getting the PRO-10 setup. I was looking at the installation instructions for the PRO-10 and I was wondering about a few things. The connections for "trigger edge" and "trigger" what exactly are those? like where do they hook up to? It looks like I can wire up the Tach signal and 12V ignition switch to my ECU harness, but not sure about the trigger edge and trigger.
Old Aug 18, 2005 | 06:41 AM
tony1's Avatar
Allen's car is running motec, and by honda ecu i mean any form of tuning a honda ecu (hondata, neptune, chrome, etc.) As for the "trigger" it's the same as the white wire on the MSD. That's the trigger input to the ign. box. The "trigger edge" is refering to what type of signal the trigger is. It's always going to be a square wave signal. With a square wave signal for an ignition signal, one edge is going to be constant and the other will vary with rpm. Honda ecu's trigger off the rising edge, which is what msd's are setup for. The M&W box is configurable to trigger from either edge. You leave that pin alone for a falling edge trigger or you ground that pin if you're using a rising edge trigger. If you use the wrong edge the timing will move with rpm, outside of what the ecu is telling it.
Old Aug 22, 2005 | 06:49 AM
Arturbo's Avatar
Better than steak
25 Year Member
M&W ignitions are on their way!
Old Aug 22, 2005 | 06:50 AM
wantboost's Avatar
Who is Mr Robot?
i've been looking at running one, but the one i need for my coil on plug is 900 bucks
Old Aug 22, 2005 | 06:57 AM
tony1's Avatar
Default Re: Who carries M&W products? (wantboost)
You could do the 2 channel box and run wasted spark, I think it's a couple hundred bucks cheaper.
Old Aug 22, 2005 | 07:00 AM
wantboost's Avatar
Who is Mr Robot?
but c.o.p>wasted spark. lol
unless tony1 wants to sponsor me
Old Aug 22, 2005 | 07:05 AM
tony1's Avatar
haha, that is true, sounds like you're in a bad situation. lol
Old Aug 22, 2005 | 07:07 AM
wantboost's Avatar
Who is Mr Robot?
yea, i'm pretty much poor, i have everythign for my build but ignition . it would be really cool cos i'll put teh tony1 logo on the car ( i show it alot).
Old Aug 22, 2005 | 07:28 AM
vaporboy12's Avatar
nice try wantboost hehe i wish everything was that easy hehe
wantboost's Avatar
Who is Mr Robot?
Default Re: Who carries M&W products? (vaporboy12)
actually for me it was that easy with one company
i've got mad skillz y0!
Old Aug 22, 2005 | 07:32 AM
vaporboy12's Avatar
tony
if you run a pro 10 on a stock ecu(neptune) what can i do about a 2 step. i know the neptune has one but doesnt build the kinda boost i want to see off the line.
does mw offer something?
Old Aug 22, 2005 | 07:35 AM
tony1's Avatar
M&W doesn't have any form of ign. cut for a 2 step, so your ecu will have to do it. How much boost do you want to leave with? Most cars will make 4-5psi on a honda ecu cut, and you very rarely need more than that unless you have a very big turbo.
Old Aug 22, 2005 | 07:48 AM
vaporboy12's Avatar
well im running a t3/67 h.o. with the Neptune 2 setup i build like maybe 2 psi with my msd im building like 8-11psi
also will i got you here i really interested in motec for my t4 setup next year
everyone has different opines. how much will a full motec setup run me for a Honda.
Old Aug 31, 2005 | 07:28 PM
reactiondc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">well im running a t3/67 h.o. with the Neptune 2 setup i build like maybe 2 psi with my msd im building like 8-11psi
everyone has different opines. how much will a full motec setup run me for a Honda. </TD></TR></TABLE>wierd i have two friends running neptune and one builds 8lbs on the two step and the other hits like 20lbs(not on purpose though)
Old Aug 31, 2005 | 07:58 PM
vaporboy12's Avatar
i dont see a stock ecu building 20psi of boost
Old Aug 31, 2005 | 08:06 PM
Default Re: (vaporboy12)
i did
