vtec help?
Old Aug 17, 2005 | 06:49 PM
IA95civicDX's Avatar
Default vtec help?
i have a jdm d15b and i need to know were the knock sensor is and if i will need to jack the car to get at it. also was wondering if i just need three wires to wire vtec (pressure plate, soleniod and knock sensor) and what gauge of wire to buy for these.
thanks- sean
Old Aug 17, 2005 | 07:17 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: vtec help? (IA95civicDX)
you'll need a jack and a stand, the light green connector i believe it is, under your intake manifold. 3 wires, v-tec ground, v-tec control, knock sensor, do u need to know the the pin out at the pcm?
Old Aug 17, 2005 | 07:50 PM
Default Re: vtec help? (95DxSi-R2)
i just need to know which one is the ground now, thanks
and the gauge of wire i should buy
Old Aug 17, 2005 | 08:26 PM
i know some one here has to know this stuff
vtechjunkie
Nov 29, 2009 03:22 PM
jordan2305
Oct 20, 2008 04:40 PM
turbo teg
Apr 24, 2005 11:34 PM
Nextelbuddy
Apr 4, 2003 03:06 PM
HybridRexy
May 5, 2002 08:19 PM
