help JDM B16A2 on 98 hatch .
Old Aug 17, 2005 | 06:25 PM
redEH2's Avatar
Default help JDM B16A2 on 98 hatch .
i need help, i just bought a complete jdm b16a2 swap . It also came with the harness and a jdm p30 ecu . Right now im rolling a obd2 sohc vtec motor . What all do i need to convert in order to use the p30 computer and keeping it all obd1? i would appreciate any help thanks.
Old Aug 17, 2005 | 06:37 PM
redEH2's Avatar
Default Re: help JDM B16A2 on 98 hatch . (purpleEJ6)
bump
Old Aug 17, 2005 | 07:09 PM
UpgradesLLC's Avatar
i was thinking the b16a2 was already obd2, but if you wanting to convert to obd1, you'll need to get a obd2-obd1 ecu conversion harness from someone like weapon r or simliar to plug the obd1 ecu into the main car harness.
Old Aug 18, 2005 | 07:53 AM
redEH2's Avatar
Default Re: help JDM B16A2 on 98 hatch . (UpgradesLLC)
yeah that what i thought to but i think i also have to wire up the distributor . But thanks
Old Aug 18, 2005 | 08:10 AM
BlazedD's Avatar
WestSPEC
u have to convert a lot of things to obd1 i believe..ignition and shyt...
not sure though..
Old Aug 19, 2005 | 02:13 PM
redEH2's Avatar
Default Re: (BlazedD)
ok i know that already.
Old Aug 19, 2005 | 06:07 PM
kNOwLedGeDA9
Guest
Posts: n/a
Default Re: (purpleEJ6)
Ok.
1. B16A2 is a USDM engine. Hell, any B##X# is USDM
2. What you mean is that you got a 2nd generation B16A.
3. All you need to do is use an OBD1 distributor (pinned to your stock OBD2 engine harness), ECU and OBD2-OBD1 conversion harness. I think you don't even have to change the injectors.
Old Aug 20, 2005 | 03:22 PM
redEH2's Avatar
Default Re: (kNOwLedGeDA9)
thanks
:::SIRll_EJ1:::
14
Feb 18, 2010 04:14 AM
Redprelude98
Jan 9, 2009 11:46 AM
97DGreenEx
Oct 13, 2006 06:21 PM
pK1spooled
Oct 1, 2004 06:47 AM
inline4
15
Sep 9, 2003 03:03 PM
