rear o2 sensor
Old Aug 17, 2005 | 06:02 PM
Dave The Flave's Avatar
Default rear o2 sensor
alright, so i got this brilliant idea. You see, I wanna test pipe, but I dont wanna pay 3,000 dollars if i get caught with it. So i bought a stock cat convertor for 30 bucks and im gonna punch out all the honeycombs inside. Now I've got a free flowing cat that will inspect visual if i get pulled over. Then every two years for smog i can swap my normal one back in.
Now here's my question: with the exhaust going straight through, is it gonna trip anything on my rear o2 sensor? if so, what will it do, i can't remember which o2 sensor is the one that controls the fuel. Thanks for your help.
Old Aug 17, 2005 | 06:04 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: rear o2 sensor (Dave The Flave)
yes, it will throw a code, probably for rich
Old Aug 17, 2005 | 06:07 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: rear o2 sensor (95DxSi-R2)
upstream controls fuel, downstream will have a slight roll in it, but is mainly used for cat efficieny? your car will probably run a little bit poor, but not bad
Old Aug 17, 2005 | 06:12 PM
pdiggitydogg's Avatar
Yes, you wil get a cel from that...
No, thats not an original idea
Old Aug 17, 2005 | 06:17 PM
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you wil get a cel from that...</TD></TR></TABLE>
Dammit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">No, thats not an original idea</TD></TR></TABLE>
Well, there goes my glory
then how do test pipes not throw cels?
Old Aug 17, 2005 | 06:30 PM
they do
Old Aug 17, 2005 | 06:55 PM
once again, dammit.
Is an o2 simulator the only way i can make it work, and if so where can i find one? I searched froogle and got some results but it was pretty inconclusiv, couldnt tell if they would work on my car or not
Old Aug 17, 2005 | 07:08 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: (Dave The Flave)
pretty much, unless you can make it have a constant voltage of like .75-.80
Old Aug 17, 2005 | 08:50 PM
urnotfast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave The Flave &raquo;</TD></TR><TR><TD CLASS="quote">once again, dammit.
Is an o2 simulator the only way i can make it work, and if so where can i find one? I searched froogle and got some results but it was pretty inconclusiv, couldnt tell if they would work on my car or not</TD></TR></TABLE>
i have been running my car using your brilliant idea for a while and i have a o2 sim from kteller.com and it works flawlessly not a single problem.
peace
eric
Old Aug 18, 2005 | 04:16 AM
You could also try wrapping your 2ndary o2 in aluminum foil, and leave it hanging outside the bung. Ive never tried it, but Ive heard it works.
95_Civic_4dr
20
Nov 4, 2010 11:24 AM
poet_x
May 7, 2008 07:31 PM
pumpkyn
Jan 30, 2006 11:59 PM
Ge.ES.AHH
Oct 10, 2004 11:21 PM
s.cali alan
May 28, 2004 12:39 AM
