Metallic clunk coming from driver's side front end while turning wheel. (SEARCHED)
Old Aug 17, 2005 | 05:27 PM
StyLz's Avatar
Default Metallic clunk coming from driver's side front end while turning wheel. (SEARCHED)
This is happening to a friend of mine's car. A 1995 Civic Si (Canadian) I was just outside checking this out to see if it was a CV boot or axle however here's a description of the problem.
This does not happen when there is no weight on the wheels (jacked up) so I've got a feeling it's a worn balljoint. However when the car is sitting on the ground whether moving or not when the wheel is jerked to the left there is a loud clunking noise. I can feel the reaction to this clunk all the way up into the upper control arm so I'm thinking either a) worn balljoints or b) tie rod end or c) wheel bearings
Does anyone have a clue as to what this might be? It's getting progressively worse. I was just driving the car and even if the wheel was turned slightly the noise would happen.
Thanks in advance guys!!!
Old Aug 17, 2005 | 05:51 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: Metallic clunk coming from driver's side front end while turning wheel. (StyLz)
did you put the jack under your lower control arm to take the wieght off the lower ball joint?
Old Aug 17, 2005 | 06:12 PM
freakasis's Avatar
jack up the car from the frame (behind the front wheel) and try and move the wheel assembly. if it moves left and right, tie rod. if it moves in and out, ball joint. spin the wheel if you hear grinding, bearing. and of course visually check the axles.
Old Aug 17, 2005 | 06:37 PM
StyLz's Avatar
Thanks guys. I knew it was one or the other. I jacked it up again before she went home and determined it's a tie rod.
prelude_93vtec
Sep 11, 2009 10:18 AM
jmai86
Suspension & Brakes
Jul 19, 2009 04:32 PM
ke98248
Oct 23, 2007 12:10 PM
90H22
Jan 28, 2003 09:47 AM
bad93ex
Jan 7, 2003 05:22 AM
