SOHCs with cams, springs etc...what do you idle at...
Right now I'm idling at 1100rpm, seems a little high but the guy I talked to from Crane said with my setup (Crane stage 1 cam, springs, titanium retainers) that I won't pull enough vacuum unless its up that high. If I try and idle at 1000rpm, it will occasionally take a **** when I put the clutch in and stall out.
So to all the other people with different cams etc in their SOHCs (really D16s, I don't care about the F22 guys
), what are you idling at? I'm not sure where the cam gear is set right now, but if its not 3 degrees advanced like they recommend, I'm going to bump it up and then see where that gets me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">right around 1000 cuz im too lazy to bring it down...
zex cam
crower valve train</TD></TR></TABLE>
What do you run for engine management/have you tried bringing it lower?
zex cam
Crower turbo cam, crower springs and retainers, fully ported and polished, titanium retainers, 750 rpm
I pull about 16-18 inches oof mercury at idle with this cam also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveG »</TD></TR><TR><TD CLASS="quote">What do you run for engine management/have you tried bringing it lower?</TD></TR></TABLE>
yeah i can lower it but haven't
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool »</TD></TR><TR><TD CLASS="quote">I idle like the guys above, but my question is why would it matter what RPM you idle at as long as your A/F is around the 14.7 range? Between 500-1300rpm, what we be the difference?</TD></TR></TABLE>
you're pulling in more air at 1300 rpm compared to 500 rpm.. so ur wasting gas
93formula
May 1, 2005 09:57 AM
Boostage
11
Nov 27, 2004 04:25 PM
