Ground Problem
Old Aug 17, 2005 | 03:31 PM
Punker1234's Avatar
Default Ground Problem
heya, i posted a few weeks ago how i had a idle issue, couple of people mentioned it was a vacuum leak. Well fix that but the cra still idles. Then i noticed today, i flipped my lights on WHILE it was fluctuating and it seem to go to a perfect idle. Is that a ground issue i imagine? Am i probably missing a ground or something since there was a swap somewhat recently? thanks! ALSO if i do leave my lights on for awhile, the car will then again to idle funny
Old Aug 17, 2005 | 04:07 PM
Punker1234's Avatar
Default Re: Ground Problem (Punker1234)
up
Old Aug 17, 2005 | 05:15 PM
Punker1234's Avatar
Old Aug 17, 2005 | 08:04 PM
Punker1234's Avatar
anyone got a clue?
Old Aug 17, 2005 | 09:03 PM
Relic1's Avatar
that could be from the higher idle from the ELD telling the ECU that there is more of a load on the system.
Old Aug 17, 2005 | 09:41 PM
Punker1234's Avatar
Default Re: (Relic1)
ELD?
Old Aug 17, 2005 | 10:21 PM
SammyYankee's Avatar
Was good i had the same problem where it would rev wierd as hell but you should check your throttle cable cause the boot could cover up where the cable is frayed or is comming loose change your throttle cable then you should be fine
Old Aug 17, 2005 | 10:28 PM
Punker1234's Avatar
Default Re: Ground Problem (SammyYankee)
hehe cable is good, i live in the engine bay haha, had so many problem with this car haha like little misc stuff that i don't know hwo to take care of haha
Supp Dude1
10
Sep 17, 2013 12:21 PM
dougsunny
Jul 19, 2010 06:00 PM
menappi
Jan 27, 2007 07:44 PM
korndog
Sep 8, 2004 09:51 AM
sleepyhamsterlx
Jan 6, 2004 07:30 PM
