Q on a price I was quoted.
Old Aug 17, 2005 | 12:35 PM
xEnderx's Avatar
Default Q on a price I was quoted.
You guys think $250 is too much for a 99-00 Si cluster? I really need a cluster since my temp gauge doesn't work and I will be making a cross country move in about 2 months. Just want input from site members.
Old Aug 17, 2005 | 12:37 PM
nocturnaldragon's Avatar
Default Re: Q on a price I was quoted. (xEnderx)
not to bad, Im sure you can find it a lot cheaper if you wait and look around I got my del sol cluster for less then 100 shipped. the 250 is about what you'd pay from a dealership.
resol's Avatar
yes sir, 250 is alot
b 1 6 a 2's Avatar
Yes, that is high priced. You can almost get a nice ctr for $100 more.
http://cgi.ebay.com/ebaymotors...ZWDVW
I bought my si cluster for $180
Old Aug 17, 2005 | 12:43 PM
streetracerof06's Avatar
Default Re: ([civic])
go to http://www.ebaymotors.com youll find one alot cheaper.
Old Aug 17, 2005 | 12:46 PM
xEnderx's Avatar
Default Re: (streetracerof06)
I knwo I could get cluster's cheaper. Right now I am using an EX one. I put my B16B in a few months ago....so I kind awant a workign temp gauge. CTR cluster is stupid to have in the US IMO.....miles are what we need, not KPH.
I guess I'll try to talk the dude down or somthing. If I can get it for 200 even then I will consider it well worth the price.
Old Aug 17, 2005 | 12:55 PM
northkai3's Avatar
Default Re: (xEnderx)
are the jdm clusters plug and play or is their wiring involved example have a 95 cx with no tach looking to put this in!
http://cgi.ebay.com/ebaymotors...wItem what do u guys think?
Old Aug 17, 2005 | 12:56 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
If the only reason your looking to replace the cluster is because the temp gauge isn't working do the following to make sure it is actually the gauge.. Ground the wire going to the engine coolant temp sending unit (single prong under dizzy) and turn the ign. switch to the on position. If the guage moves replace the ECT sending unit.. If it doesn't move check for continuity between this wire and the one behind the gauges.. If this checks out and the guage still doen't move when the wire by the engine is grounded, replace the gauge, it's simple. The part number for the fuel/temp guage out of the 99-00si (will work on any EK) is: 78130-S01-L01.
You can scoop this from http://www.hondapartsdeals.com for like $25, or just print out the page and take it to the local dealer, they will usually match as close as they can.. Now $25 and an additional 30minutes of work or $250 even ~$180, it's a no brainer to me... Just to give you a different scope on the situation..
Old Aug 17, 2005 | 12:57 PM
fbmsucks's Avatar
where/who was the quote from?
Seems like the typical price should run you 100-150.
Old Aug 17, 2005 | 01:06 PM
A.E Motoring's Avatar
Default Re: Q on a price I was quoted. (fbmsucks)
damn 45 dollars shipping???? ****...u can find a EX cluster on here for like 70 bucks
Old Aug 17, 2005 | 01:15 PM
northkai3's Avatar
Default Re: Q on a price I was quoted. (SPNFEDEJ)
well the item is 45 because its located in singapore but i didnt ask u if the s&h was expensive i asked if the the jdm clusters were plug and play for the according years exampl i have a 95eg want to put in a jdm si eg cluster is this plug and play or will i have to relocate wires in the plugs?
Old Aug 17, 2005 | 01:56 PM
it will plug in fine
EDIT: except the SRS plug..there is no plug for the SRS one...so what i did was take the plug from the back of the old cluster and put it into the SIR one...its yellow
Old Aug 17, 2005 | 03:11 PM
Earthworm Jim's Avatar
It must be brand new right?
Old Aug 17, 2005 | 03:12 PM
.:Swig:.'s Avatar
Default Re: Q on a price I was quoted. (TheGeneral)
holy moly thats expensive, got mine for 90 bucks with 43k from a close individual
Old Aug 17, 2005 | 04:58 PM
specv5150's Avatar
Default Re: Q on a price I was quoted. (00mofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00mofo &raquo;</TD></TR><TR><TD CLASS="quote">holy moly thats expensive, got mine for 90 bucks with 43k from a close individual</TD></TR></TABLE>
Yeah you got a hook up. I personally have not seen an SI cluster for UNDER 200 on HT and they regularly go for close to that on ebay. I have been keeping my eye on them since I would like to have one but not at that price. WAAAAY too much money for a little bit longer tach
Old Aug 17, 2005 | 05:20 PM
xEnderx's Avatar
Default Re: Q on a price I was quoted. (specv5150)
Yes, I am 100% positive that the mechanism inside the cluster is broken. Its all good....the cluster was free and it still works great except for the temp thing. I know my car never runs hot, so its not a big issue either.
IMO 200 is a fiar price for an Si cluster....sometiems folk stry to charge more for low mileage clusters, but that is just retarded.
Old Aug 17, 2005 | 06:23 PM
.:Swig:.'s Avatar
i wouldnt mind getting a gsr cluster
Old Aug 17, 2005 | 06:25 PM
llxzxll's Avatar
it really isn't hard reading KPH. my jdm itr cluster in my EK works perfectly fine for me. PLUS...can't beat $140 shipped to my door straight from japan.
Old Aug 17, 2005 | 07:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEnderx &raquo;</TD></TR><TR><TD CLASS="quote">Yes, I am 100% positive that the mechanism inside the cluster is broken. Its all good....the cluster was free and it still works great except for the temp thing. I know my car never runs hot, so its not a big issue either. </TD></TR></TABLE>
$250 Is almost asking too much for a brand new one.
Old Aug 17, 2005 | 08:12 PM
midwesta's Avatar
Default Re: Q on a price I was quoted. (resol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by resol &raquo;</TD></TR><TR><TD CLASS="quote">yes sir, 250 is alot</TD></TR></TABLE>
Old Aug 18, 2005 | 07:05 PM
Default Re: (HondaFanatic708)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote">If the only reason your looking to replace the cluster is because the temp gauge isn't working do the following to make sure it is actually the gauge.. Ground the wire going to the engine coolant temp sending unit (single prong under dizzy) and turn the ign. switch to the on position. If the guage moves replace the ECT sending unit.. If it doesn't move check for continuity between this wire and the one behind the gauges.. If this checks out and the guage still doen't move when the wire by the engine is grounded, replace the gauge, it's simple. The part number for the fuel/temp guage out of the 99-00si (will work on any EK) is: 78130-S01-L01.
You can scoop this from http://www.hondapartsdeals.com for like $25, or just print out the page and take it to the local dealer, they will usually match as close as they can.. Now $25 and an additional 30minutes of work or $250 even ~$180, it's a no brainer to me... Just to give you a different scope on the situation..</TD></TR></TABLE>
IMO 200 is a fiar price for an Si cluster....sometiems folk stry to charge more for low mileage clusters, but that is just retarded.</TD></TR></TABLE>
Old Aug 18, 2005 | 08:31 PM
papito_85's Avatar
Old Aug 18, 2005 | 08:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEnderx &raquo;</TD></TR><TR><TD CLASS="quote">You guys think $250 is too much for a 99-00 Si cluster? I really need a cluster <U>since my temp gauge doesn't work </U>and I will be making a cross country move in about 2 months. Just want input from site members. </TD></TR></TABLE>
IMO 200 is a fiar price for an Si cluster....sometiems folk stry to charge more for low mileage clusters, <U>but that is just retarded</U>.</TD></TR></TABLE>
Almost as retarded as spending 10 times as much to fix the problem that seemed like it was the only real concern based on the origional post..
Old Aug 18, 2005 | 08:41 PM
SpydiR's Avatar
Default Re: Q on a price I was quoted. (HondaFanatic708)
hey man, why not just buy a stock cluster w/working temp gauge and swap the mechanism over to your current cluster?
BlownFG2
Jun 20, 2011 03:42 PM
pooorman's type-r
Feb 22, 2009 10:24 AM
jdmsohc2nr
Feb 4, 2009 08:16 PM
RacingShoeBox
Nov 29, 2005 10:27 PM
ek9vboi
Jun 21, 2003 09:54 PM
