DA rear disc swap
What is a good price for a set of DA trailing arms for a rear disc swap? I've seen junkyards get from $50 to $200 for them. And then I have seen people on here selling them for 2 to 3 hundred.
If all you want are the trailing arms, sure pay the $50! If you want the full conversion, $250-$350 isn't a bad deal, as piecing together part by part will surely cost you more than that.
I actually have the trailing arms, prop valve, energy bushings (not pressed in) already. I'm just debating whether or not to sell it. Thanks for the info guys.
someone correct me if i'm wrong but shouldn't you use the stock civic trailing arms? i thought that the integra ones were a little bit longer than the civic ones. if anyone can confirm on this let me know. (sorry, didn't mean to thread jack)
As long as I dont have to take out any more Metal Gears
dont pay more than 200 for the rears. I got my complete teg brake swap for my EK for 300, that included complete front knuckles, complete rear trailers, e brake cables, rear upper compensator arms, and teg rear LCA's. No prop valve though. But after I sold the LCA's, i used that $$ to get one from a 99 SI. Apparently that guy i got it from did a 5 lug conversion, so he didnt need the LCA's. Too bad he didnt know they were worth some $$ to EG owners who want to run swaybars. Good luck in your quest
I bought my set up for $120.00 Non-ABS from a 1990 DA.
Look up EL Vap133 and MAHATMA These guys are selling their complete swaps.
See my write up on performing the whole rear swap.
https://honda-tech.com/zerothread?id=1334534
Modified by EF4_Anthony at 9:54 PM 8/20/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF4_Anthony »</TD></TR><TR><TD CLASS="quote">I bought my set up for $120.00 Non-ABS from a 1990 DA.
See my write up on performing the whole swap.
https://honda-tech.com/zerothread?id=1334534</TD></TR></TABLE>
added link to favorites
Modified by teler86 at 5:37 PM 8/20/2005
I'm looking to add rear discs to my 1991 Civ hatch. What's the difference in the DA rear discs and teggy discs? Please be as specific as you can...dimensions, calipers, pads, etc etc...
asianflava
Dec 8, 2008 11:14 AM
specialized108
21
Nov 7, 2008 04:44 PM
