92 Civic Si, boggled by 1 wire??
where in the world is the light green/red wire that is used for the door trigger located?? I have been looking for some time and cant figure it out. Any plug that is YELLOW is for the SRS correct? Well the yellow plug that is on the upper right hand side of the pic below (has grey wires coming out the front) has a light green w/ red strip wire going into the back of it. Also has a light green w/ black stripe coming into the back of it. I dont think this is it but could be wrong. Anyone know for sure where this is?
well see by driver's kick panel, those would be the wires that run along the door sill under the carpet right (on the driver's side)? I've looked at those bundle of wires and no light green/red wire? There is a dark green/red but ...?? Maybe i'm colorblind or something
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b204dr »</TD></TR><TR><TD CLASS="quote">COULD JUST FOLLOWING IT FROM THE DRIVERS KICK PANEL
</TD></TR></TABLE>Or the dome light.. Yes all yellow shielded wiring and yellow clips are for the SRS. Try not to **** with these or you could get an airbag i the face when not expecting it..
it is easiest to find it in the driver kick panel.if memory serves,it is a larger gauge than the other wires in that bundle.
Chris
Chris
kelviiv
Audio / Security / Video
23
Sep 10, 2010 09:46 PM
Unjockable
Jan 27, 2004 07:25 PM
