Why won't this car start??
Old Aug 17, 2005 | 08:46 AM
chad's Avatar
Moderator
Default Why won't this car start??
92 hatch
91 si engine with obd1 injectors, obd1 dizzy...all obd 1 sensors that are neccassary.
changed head gasket....
WON"T START
has spark
has fuel
has compression
IS AT TDC
cam gear is UP
crank pulley is where it is suppose to be....
piston 1 and 4 are at top
will act like it wants to start but won't
have changed ECU's
new main relay
SOLID CHECK ENGINE LIGHT
does NOT even flash when ignition is turned to start position. stays solid...have tried 2 different ecu's
anyone have any suggestions?
Old Aug 17, 2005 | 10:00 AM
Dancing is Forbidden's Avatar
Default Re: Why won't this car start?? (chad)
Check your wiring. Solid CEL means bad ECU or ground fault in wiring.
Old Aug 17, 2005 | 09:15 PM
FalkenSiR's Avatar
Default Re: Why won't this car start?? (ih8jdm)
Most cars won't start without proper grounding.
Old Aug 18, 2005 | 12:45 AM
WickedSol's Avatar
Default Re: Why won't this car start?? (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">Most cars won't start without proper grounding.
Engine grounds...
Old Aug 18, 2005 | 06:02 AM
chad's Avatar
Moderator
Default Re: Why won't this car start?? (WickedSol)
thermstat ground...tight
tranny ground....tight
valve cover ground....tight
Old Aug 18, 2005 | 06:45 AM
BlazedD's Avatar
WestSPEC
ground the neg cable on the tranny around the starter as well..
check ur fuel stuff...
Old Aug 18, 2005 | 06:46 AM
UpgradesLLC's Avatar
i would say check grounds like everyone else said, and i would also check the valve clearances, i had a prelude do the same thing and all it took was a valve clearance to the looser side
Old Aug 19, 2005 | 10:03 AM
Specail Ed's Avatar
I know exactly what your problem, it's rather simple. YOU'RE WORKING ON IT!!! Burn!!!
niceprelude
May 12, 2012 09:34 PM
eghatch515
Oct 8, 2008 08:07 PM
tdizz07
Jun 2, 2007 07:02 PM
jasongallagher
May 27, 2002 01:36 PM
