93 mini me
Old Aug 16, 2005 | 09:50 PM
eskimo_usd's Avatar
Default 93 mini me
i helped my friend do a mini me and we got to start up and everything. the only thing wrong with it is that it ideals between 1000rpm and 2500rpm, but not right in the middle of those two, it ideals as if it was reving. im not sure if any of this makes sense but thanks for any help.
Old Aug 16, 2005 | 10:22 PM
95dxhatch's Avatar
sounds like a vacuum leak. are all hoses connected and the intake manifold bolted tightly to the head. or did you forget the gasket there or between IM and throttle body?
Old Aug 16, 2005 | 10:54 PM
eskimo_usd's Avatar
Default Re: (95dxhatch)
we didnt disconnect anything from the intake manifold, we just unbolted it and that was it.
Old Aug 17, 2005 | 02:28 AM
Br1anPham's Avatar
Default Re: (eskimo_usd)
bad intake manifold gasket? all IM bolts/nuts torqued to specs?
check iacv.
check coolant levels.
Check all vacuums lines again even if all you did was unbolt the intake manifold.
Old Aug 18, 2005 | 10:05 PM
eskimo_usd's Avatar
Default Re: (Br1anPham)
will the ecu cause that to happen by any chance
Lilsoldierbenny
Apr 16, 2010 07:27 AM
hectic57
Mar 18, 2008 07:16 PM
99GSRTurbo
Jan 2, 2007 04:17 PM
jdmeg61
Oct 29, 2006 08:12 PM
mookie
Aug 30, 2004 12:25 PM
